More problems arise, what is the cause of my trans having to heat up in the cold in order for it to switch gears. It'll top out at the rpm if I try to go 35 Mph
Thanks bros, at least its not expensive i think
Replace with junkyard trans or did you have it rebuilt in the past?
The part itself isn't expensive but does require for the trans to be torn apart to get to it. Sorry about your luck but either way you're gonna have to be diving into the trans.
Well, I guess It wont be getting fixed. I'm not paying anymore. It already got replaced twice within a couple months.
What got done?
Hell...what's actually happening. No gear engagement or it won't shift properly?
it got rebuilt less than a year ago
