Thread: Getting horrible gas mileage 11 mpg....po420 code
Results 1 to 20 of 20
  1. #1 Getting horrible gas mileage 11 mpg....po420 code
    Sep 2012
    Dealership
    I have a 2001 Grand prix gt 99,000 miles. I'm going by the mpg on the dash info center. I have gotten to around 17mpg in the summer (po420 code was present then also)..but now I get around 11-12 mpg. I know its cold outside now but still.
    I'm looking to order a cat and down pipe from zzp..not sure if its 2 or 3 inch though.
    Also will be doing a tune up asap...Not sure how much that code can affect gas mileage but I have to try something.
    P0420 = catalyst system below efficiency
    04 Comp G.
    Go with a 2" since your n/a you don't want to lose some of your low end torque.
    04 Comp G.
  4. #4 Re: Getting horrible gas mileage 11 mpg....po420 code
    I bet the highflow cat that ZZP uses will still set off the check engine light.
    P0420 on any 01+ car will affect gas mileage alot.
    ^ Spark plug fouler trick? Or have your PCM tuned.
    04 Comp G.
  6. #6 Re: Getting horrible gas mileage 11 mpg....po420 code
    Or just a buy a quailty cat and not deal with the bull**** sounds like a way way better idea to me.
    But its just that too many people are cheap asses.
    True! Then again we drive Grand Prix so its not exactly like most of us have Maserati money
    04 Comp G.
  8. #8 Re: Getting horrible gas mileage 11 mpg....po420 code
    Sep 2012
    Dealership
    Yeah I was told with the zzp cat, that would most likely have to be done..
    Only one way to find out try it without and then go from there.
    04 Comp G.
  10. #10 Re: Getting horrible gas mileage 11 mpg....po420 code
    Sep 2012
    Dealership
    I'm not totally against buying a more expensive cat, just reading around and a lot of people were going with the zzp cat, I guess for more performance reasons. Which is cool but I see that the code will probably still be present. I just need to get it taken care of, wasting gas at its price, is not cool.
  11. #11 Re: Getting horrible gas mileage 11 mpg....po420 code
    Sep 2012
    Dealership
    @REDCOMPG Yeah your write I'm going to order one and see what happens.
    Think about this if your going for a performance gain ZZP downpipe then if you wanted a quality cat that will have to be purchased and welded on. Unless you want to throw a bunch of money into it..give the fouler trick a chance em after all its a few bucks.
    04 Comp G.
  13. #13 Re: Getting horrible gas mileage 11 mpg....po420 code
    Sep 2012
    Dealership
    That's true the follower trick you mean simulator?
  14. #14 Re: Getting horrible gas mileage 11 mpg....po420 code
    Sep 2012
    Dealership
    Also its a 2.5 downpipe.....
    04 Comp G.
    Unless you know you want to spend more money if that's the case ill give you my Paypal and you can send me the difference and ill put it towards hookers and blow 8)
    04 Comp G.
  17. #17 Re: Getting horrible gas mileage 11 mpg....po420 code
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Quote Originally Posted by redcompg View Post
    unless you know you want to spend more money if that's the case ill give you my paypal and you can send me the difference and ill put it towards hookers and blow 8)
    Party with Red.
  18. #18 Re: Getting horrible gas mileage 11 mpg....po420 code
    Sep 2012
    Dealership
    Hahahaha, Ill keep you in mind.. I Just read the post in the link you provided..very clever idea..thanks a bunch.
    No problem
    04 Comp G.
  20. #20 Re: Getting horrible gas mileage 11 mpg....po420 code
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I did the non fowler trick when I still had a high flow cat and it did the trick. Just be aware your sensor will be sad and vulnerable hanging down below the rest of the car for rocks and whatnot.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. Horrible gas mileage for my 06 GXP
    By rguy200073 in forum 5.3L V8 (LS4)
    Last Post: 03-13-2014, 01:10 AM
  2. Horrible Gas Mileage
    By Cody Benjamin in forum Engine
    Last Post: 04-22-2012, 01:51 PM
  3. Horrible gas mileage - help!
    By aziff in forum General Tech Discussion
    Last Post: 05-02-2011, 07:14 PM
  4. Horrible mileage
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2011, 10:59 PM
  5. horrible gas mileage!
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2010, 12:06 PM
