Thread: 2004 gtp blown engine
Results 1 to 14 of 14
  1. #1 2004 gtp blown engine
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    Just bought a 04 gtp with a blown engine knocking doesn't sound to consistent with lower end. Could I just use a l26 lower end for it be good? Or find a charged engine to replace? There are tons of n/a engines on Craig's around here for good prices.
  2. #2 Re: 2004 gtp blown engine
    GT Level Member Shiftingshaddow's Avatar
    KC
    im pretty sure i saw the same listing and was going to call about that today. ha ha. what color is the car? it didn't say. they wanted 1900.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
    Jul 2012
    Kansas city
    Yup that's the one... It's white
  4. #4 Re: 2004 gtp blown engine
    KC
    cool man. good luck.
    Jul 2012
    Kansas city
    Thanks it's a very straight car but very dirty will need some serious clean up.
  6. #6 Re: 2004 gtp blown engine
    If you put a NA bottem end in you need to do other supporting mods to run the high comp block.
    Its better to find a L67 or L32 bottem end and make it a straight swap with no hassles.
    Jul 2012
    Kansas city
    Like what supporting mods? Headers? Tune? Intake? Colder plugs and tstat Which are all items I plan on running anyway
  8. #8 Re: 2004 gtp blown engine
    Headers and a tune mainly. Colder plugs and tstat arent needed if kept on the stock. But just know the NA L26 is not the best block for boost and you may need a 4.0 pulley to run it like a 3.8 on a L32 block.
    Jul 2012
    Kansas city
    A l67 will work in a 04?
    Jul 2012
    Kansas city
    I don't plan on running stock it's going to get modded well
  11. #11 Re: 2004 gtp blown engine
    Yeah, just swap brackets and top end over and thats it.
    Jul 2012
    Kansas city
    That will b the plan then there are a few l67 around here for sale ill snag one of those
  13. #13 Re: 2004 gtp blown engine
    May 2008
    Schuyler, NE
    I bought the 04 in my sig with a blown motor and stuck an L26 in it. You'll more than likely need to do some mods to accommodate for the higher compression block. Or, find yourself a L67 or L32.
    Or, the best option of all......sell the car to me.
    Jul 2012
    Kansas city
    Yea that might be the route to go they are proud of the l36..
    Oh no it will be my keeper
  1. 2004 GP-GT2... blown intake manifold, overheating, etc
    By gunbunny in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2012, 09:07 AM
  2. 2004 GP AC Question - Blown compressor release vlave
    By JeffKirk in forum General Tech Discussion
    Last Post: 08-15-2012, 09:58 AM
  3. Engine blown?
    By villanex in forum Engine
    Last Post: 03-14-2012, 05:39 AM
  4. Engine Blown
    By WagZ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 12:53 AM
