Thread: Dex-Cool Colant Question
Results 1 to 2 of 2
  1. #1 Dex-Cool Colant Question
    SE Level Member PRIXter's Avatar
    Jan 2013
    South Carolina
    I have heard about serious issues about DEx-Cool coolant. It seems there is a problem with some that it eats away gaskets over time. Some people suggest changing it over to the green stuff. My newly purchased 1998 GP has it so should I switch over or leave it alone at this point in time? It has 70K miles on it.
  2. #2 Re: Dex-Cool Colant Question
    The reality about dex is it will get gunky like oatmeal if air is in the system. Other than that, it doesn't really hurt the gaskets. Most manufacturers switched to plastic based gaskets and all found degradation in short periods of time. Ours are no different. You'll find that around the coolant ports, they typically bow in. However, I have also found bowing by intake ports that has no coolant in the area. I've also swapped out to green with serious flushing etc and within 20K when I pulled the intake off again....bowed coolant ports.
    You should perform the maintenance on the system....based on age. Personally, I fill with Anycolor as it's the most common coolant available and then there are no worries if either green or dex was in the system previously.
  1. My Cool New Pic
    By Curt7 in forum Off Topic Discussion
    Last Post: 11-10-2011, 10:45 PM
  2. The cool ZR1 around...
    By RamonGTX in forum Off Topic Discussion
    Last Post: 08-18-2011, 08:55 PM
  3. Is Everyone cool out there!
    By Sameer in forum Introductions/Noob Questions
    Last Post: 10-10-2009, 08:45 AM
  4. cool 4 anyone who has one......
    By boosting98 in forum Off Topic Discussion
    Last Post: 10-26-2008, 07:04 PM
  5. 04+ GP = Not Cool?
    By xerxescct in forum Off Topic Discussion
    Last Post: 10-13-2008, 04:50 PM
