Thread: P300 random multiple misfire
Results 1 to 8 of 8
  1. #1 Re: P300 random multiple misfire
    Jan 2013
    Southern Califorina
    I just had the same problem on a 99 gtp i just bought. what you have change are the most common problems.
    but the other common problems are the lower intake gasket, supercharger gasket, throttle boby gasket. you can check thoughs with a can for carb or brake cleaner. with the car running spray around the base of the gaskets to see if the races or stumbles. it could also be the throttle positioning sensor, if you replace that it does need to be recalibrated. I am will to bet it is one of the gaskets though, I ended up changing all 3 on mine. hope that help.
  2. #2 Re: P300 random multiple misfire
    Jan 2013
    Fridley
    Crizzo,
    Thanks for your suggestions, I have already sprayed for leaks once, but I am going to do it again tomorrow and I will let you know what I find.
  1. 97 gtp multiple cylinder misfire help.
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2012, 11:40 AM
  2. ses light for multiple cylinder misfire help!!!
    Last Post: 06-20-2012, 09:17 AM
  3. Multiple misfire?
    By Points70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2011, 12:19 PM
  4. Random multiple cylinder misfire
    By sunfiregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 08:58 PM
  5. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
