Thread: GTP Build. Sub 13 Second 300whp goals!
Results 101 to 120 of 122
Threaded View
  1. #1 GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    Goals are to get below 13 seconds and achieve 300whp with this setup. Comments and advice would be greatly appreciated for this build.
    Appearence:
    Autometer ES Vacuum/Boost, Oil temp, & Oil Pressure in A-Pillar
    Autometer DPIC in factory gauge cluster
    Autometer Phantom II Volt and Trans Temp guages near shifter
    AEM wideband (location TBD)
    Performance:
    180 degree thermostat
    Colder spark plugs
    3.4 Modular Pulley system from ZZP
    Retuned PCM by ZZP
    Cold air intake system
    Header/downpipe catted
    Stage 1 throttle body ZZP
    VS Cam with #90 springs and retainers
    Poly Engine mount
    Alternator and water pump underdrive pullies
    Rebuild:
    Replace LIM gasket
    Replace 4th gear clutch
    Transmission and coolant flush
    Replace spark plug wires
    Think this is a good setup for sub 13 and 300whp? I'll post pics and the build comes along.
  1. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  2. 300whp??
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2010, 11:27 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. What about a smaller build to 300WHP
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2008, 02:01 PM
  5. Goals for my gtp this summer
    Last Post: 02-16-2008, 02:24 PM
