Thread: 2000 GTP NO POWER AT 3000 rpm
Results 1 to 14 of 14
  1. #1 2000 GTP NO POWER AT 3000 rpm
    Jul 2012
    Beulah,nd
    Recently put a new fuel pump ,pump relay,fuel filter, and fuel pump resister in my 3800 super charged. Now t about 2800 - 3000 it has no power and if I hold the gas down the service engine starts flashing and then quits when I slow down. Any suggestions . 152,000 miles on it. Thanks
  2. #2 Re: 2000 GTP NO POWER AT 3000 rpm
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    clogged exhaust... pull the front o2 sensor, then start it and see if it helps.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 2000 GTP NO POWER AT 3000 rpm
    X2 on a clogged cat.
    or your in need of a tune up real bad.
    dont make the cel light flash, its bad for the engine. it means a catastrophic even is happening. aka multiple misfires.
  4. #4 Re: 2000 GTP NO POWER AT 3000 rpm
    Jul 2012
    Beulah,nd
    Any possibility it could be the fuel pump relay/ resistor ? Saw an article some time back on this forum about using a short copper wire to bypass the relay to keep pump on high speed. Could it be a fuel staring problem?
    Kopp
  5. #5 Re: 2000 GTP NO POWER AT 3000 rpm
    Jul 2012
    Beulah,nd
    I meant a fuel starving problem , spelling ?!?!
    anyone know where I can get that picture of using the jumper wire?
    thanks
  6. #6 Re: 2000 GTP NO POWER AT 3000 rpm
    your getting fuel.
    how many miles? last known tune up?
    flashing light is always clogged cat or you need a tune up real bad.
  7. #7 Re: 2000 GTP NO POWER AT 3000 rpm
    Jul 2011
    Michigan
    You can always check your FP at the rail if it makes you feel better. But I would just take a few minutes to take the o2 out and check it. Or you could just drill a hole in the cat lol
  8. #8 Re: 2000 GTP NO POWER AT 3000 rpm
    Jul 2012
    Beulah,nd
    Really? Drill a hole in the cat. Tell me more. What size and where on the cat
  9. #9 Re: 2000 GTP NO POWER AT 3000 rpm
    Quote Originally Posted by Kopp View Post
    dont do that unless you can weld it back up.
    last known tune up please.
  10. #10 Re: 2000 GTP NO POWER AT 3000 rpm
    Jul 2011
    Michigan
    Well I can weld it, only reason I suggested... But ya if u cant weld, dont do it
  11. #11 Re: 2000 GTP NO POWER AT 3000 rpm
    Never Never Land
    I would do as BlackGT first suggested and pull the front 02 sensor. Def sounds like you have a clogged cat.
    My 99 was clogged so bad you could hear the motor knockin from the lack of flow.
  12. #12 Re: 2000 GTP NO POWER AT 3000 rpm
    I dont think he likes to listen.
    Flashing SES means possible cat damage, like massive misfires. The car has some problems, you might wanna listen and answer our question before you dig yourself a bigger hole.
  13. #13 Re: 2000 GTP NO POWER AT 3000 rpm
    Jan 2013
    Tolono IL
    my car did the same thing then i put a new cat on and it was all good
  14. #14 Re: 2000 GTP NO POWER AT 3000 rpm
    Akron Ohio
    New Cat problem salved! Easy and delete that u bend!
  1. 2000 GT 4 dr power window gremlins
    By disallow in forum General Tech Discussion
    Last Post: 08-28-2012, 01:20 PM
  2. 2000 gp gt #6 injector not getting power
    By 2000gts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-24-2012, 02:35 PM
  3. 2000 GTP gauge power
    By TZFBird in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2011, 10:29 AM
  4. 2000 Grand Prix A/C Not Getting Power
    By neoseeker191 in forum General Tech Discussion
    Last Post: 05-21-2009, 07:13 PM
