Thread: Gauge wiring
Results 1 to 19 of 19
  1. #1 Gauge wiring
    The Boss Iceman6669's Avatar
    Jun 2011
    So I was looking at the wiring for my Boost gauge from GlowShift and I had a question.
    It has 4 wires on it. A Ground, A Constant 12v, A Switched 12V, and a Headlight 12V(for dimming use... NOt going to do that)
    Well I already plan on running it to my switch I have for other interior lights.... And was wondering if I can just wire the constant and switched together to the hot side of my switch?
    2011 F-150 Yote powered
  2. #2 Re: Gauge wiring
    Ohio
    just do the switched and tape the headlight and the constant up
  3. #3 Re: Gauge wiring
    Jun 2011
    Will that work? If I only hook up my switched power? Will it cause it to switch colors every time I shut the car off or anything DUMB like that?
  4. #4 Re: Gauge wiring
    Ohio
    no, there should be a button to change the color
  5. #5 Re: Gauge wiring
    Jun 2011
    but it claims that it will save colors when you shut the car off so I dont have to change it everytime..
  6. #6 Re: Gauge wiring
    Ohio
    my buddy had me wire in the temp gauge on his truck. i just did the ground and switched 12v......his stayed the same color at all times unless he pressed the button
  7. #7 Re: Gauge wiring
    Jun 2011
    ok. Just just run the switched wire and ground... Ok I think I can do that.
  8. #8 Re: Gauge wiring
    Ohio
    easy peasy
  9. #9 Re: Gauge wiring
    Apr 2011
    Vassar, Mi
    My glow**** boost gauge is wired with constant and switched together and it doesn't save colors. I have to reset it back to red every time I turn the car off. Was looking at buying autometers just because of that
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  10. #10 Re: Gauge wiring
    Jun 2011
    well that tells me I CAN NOT wire them together....
  11. #11 Re: Gauge wiring
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Josh, i have my switched and constant wires mixed up.
    The color resets everytime i turn the car off.
    Dont do the dimming wire, its pointless. But make sure you do that switched and constant correctly.
  12. #12 Re: Gauge wiring
    Jan 2013
    Tolono IL
    couldnt u hook up the constant and switched 12v together bc they both 12v
  13. #13 Re: Gauge wiring
    Jan 2013
    Tolono IL
    oh thats what u said lol
    Jun 2011
    I don't plan on doing the dimming crap. And colors resetting is exactly what I DON'T want. WE can figure it out when I m all ready for us to install it.
  15. #15 Re: Gauge wiring
    SE Level Member JEBSR's Avatar
    Clarksville, Tn
    The constant power is what keeps it from resetting the colors. Make sure that wire is hooked up to constant and not switched power and it will work fine.
    If it has Tits or Wheels, it's nothing but Trouble
  16. #16 Re: Gauge wiring
    Pennsylvania
    Lemme see if I remember this correctly. I think my experience has been that lacking one of the two power sources, the gauge glowed at half-light.
  17. #17 Re: Gauge wiring
    Jan 2013
    Tolono IL
    so just hook the 12v to like lets say a remote wire for a sub and it should work just fine? without resetting color? or no because the amp shuts off when the cars off
  18. #18 Re: Gauge wiring
    Clarksville, Tn
    If you want the memory to work you will have to find a constant power source and tap into it. You can do the at the fuse panel with an add a circuit connector. That way you don't have to cut any wires and splice into your harness. It's the only way to keep the colors from reseting every time you turn the key on.
  19. #19 Re: Gauge wiring
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    the cig lighter has a constant 12v source. it's quite easy to access too
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  1. Boost gauge wiring help please!
    By szalajka05 in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 04:43 PM
  2. Gauge wiring help
    By real diehl in forum Audio, Security & Visual Electronics
    Last Post: 05-17-2011, 09:08 PM
  3. Wiring Wideband Gauge
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2010, 02:05 PM
  4. wiring up my VOLTS GAUGE =] 1 Q
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2009, 01:50 PM
  5. gauge wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 08-09-2008, 12:46 PM
