Thread: Solid Motor Mounts?
Results 1 to 9 of 9
  1. #1 Solid Motor Mounts?
    SE Level Member Iceman83's Avatar
    Jan 2013
    Livermore, KY
    Where can I buy some? And do they make a real difference keeping the motor from moving as much?
  2. #2 Re: Solid Motor Mounts?
    antioch ill
    zzperformance
  3. #3 Re: Solid Motor Mounts?
    Jan 2013
    Livermore, KY
    Cool. Thanks.
  4. #4 Re: Solid Motor Mounts?
    Banned
    Jan 2013
    Colorado
    Which mounts would you guys recommend off their site?
    The Boss Iceman6669's Avatar
    Jun 2011
    ANOTHER ICEMAN??? BTW Rockauto sells solids also for wayyyyyyyyyyy cheaper.
    2011 F-150 Yote powered
  6. #6 Re: Solid Motor Mounts?
    Feb 2010
    TN
    I made mine, buy a set from rock auto (engine, trans mount) drill a a hole in each one at either end, drain the fluid well. let dry a day or so then with a caulking gun fill with RTV caulking, (got mine at O'riellys) then let dry two weeks or so (I let mine set a month) then install
  7. #7 Re: Solid Motor Mounts?
    Banned
    Jan 2013
    Colorado
    That doesn't sound all that safe to be honest. How does that hold up?
    It's actually real safe..many guys do it on other platforms when solid mounts are not available.
    04 Comp G.
  9. #9 Re: Solid Motor Mounts?
    Feb 2010
    TN
    Yep I got the idea after seeing a ton of guys on this forum do it, there is even a write on here somewhere
  1. HOW TO: Solid Mounts
    By Pure2sin in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2018, 09:19 PM
  2. Cheapest solid motor mount
    By Jay7199 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2011, 09:05 AM
  3. Solid steel dog bone motor mounts
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 10-19-2010, 08:32 PM
  4. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  5. Napa solid rubber mounts part #s?
    By blown98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2009, 08:21 PM
