Thread: Very Bad mpg need help
Results 1 to 20 of 20
  1. #1 Very Bad mpg need help
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    My car is only get between 13-15mpg right now and my muffler has a whole in it
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: Very Bad mpg need help
    I live here. UR LOSN's Avatar
    Rockford, IL
    clean the MAF, change the fuel filter, clean the air filter, seafoam it, change 02 sensor
    does the car feel sluggish at all? like you have to use more fuel than normal to get it to move?
  3. #3 Re: Very Bad mpg need help
    How far and how long do you drive? Its hole btw
  4. #4 Re: Very Bad mpg need help
    Dec 2012
    grand rapids
    at Least 10-15 miles a day
    And it was 2 in the morning I was tired af
  5. #5 Re: Very Bad mpg need help
    In town or highway?
  6. #6 Re: Very Bad mpg need help
    Dec 2012
    grand rapids
    Town
  7. #7 Re: Very Bad mpg need help
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    upstream o2, plugs/wires, clean MAF, make an intake, change fuel filter
  8. #8 Re: Very Bad mpg need help
    Dec 2012
    grand rapids
    How am I supposed to make intake ?
  9. #9 Re: Very Bad mpg need help
    Jun 2011
    Look at my Picture below this post.
    I made that.
    About 95% of people on this site make their own, and ive made three of them so far.
    Have $60 and 10 minutes of your time? Thats all it takes.
  10. #10 Re: Very Bad mpg need help
    How are we supposed to read and research?
    Click the link in my signature JJ guy, and read it. And then learn.
  11. #11 Re: Very Bad mpg need help
    Dec 2012
    grand rapids
    Just a piece of hose and some clamps
  12. #12 Re: Very Bad mpg need help
    Jun 2011
    Ill work you through it. step by step.
    By PVC pipe from lowes, and two clamps and a rubber coupler, then buy an air filter from AutoZone.
    Remove, stock air box and tubing.
    Drill hole in PVC pipe for IAT sensor to sit in.
    Clamp Air filter to PVC pipe.
    Clamp PVC pipe to throttle body with rubber coupler and two clamps inbetween.
    And boom, 10 minutes later, you now have a home made intake.
  13. #13 Re: Very Bad mpg need help
    ^^He has an '04+.
    MAF is external.
    So it'll need an extra clamp in there.
  14. #14 Re: Very Bad mpg need help
    Jun 2011
    Quote Originally Posted by blueguy91 View Post
    ^^He has an '04+.
    MAF is external.
    Negative Ghost rider.
    He has a 97, just like me.
  15. #15 Re: Very Bad mpg need help
    Jun 2011
    Jake, follow this write up:
    http://www.grandprixforums.net/simpl...res-33351.html
    It cant get much easier/straight forward than that.
  16. #16 Re: Very Bad mpg need help
    Can't see the pics at work.
    Thought it was blower car when it says GT GP
  17. #17 Re: Very Bad mpg need help
    Vancouver, WA
    Go to ZZP's site. Get a big K&N filter, intake tubing, a metal coupler to connect the tubing and filter. Bam done, $60.
    Slowest 'Cooled Gen V ever
  18. #18 Re: Very Bad mpg need help
    Jun 2011
    Quote Originally Posted by footballplaya3k View Post
    Negative on the K&N.
    Just go with Spectre from AutoZone. Trust me.
    Or
    http://item.mobileweb.ebay.com/viewi...id=80068658104
    Avoid the oily K&N crap. There good is you use the right amount of oil.
    04 Comp G.
  20. #20 Re: Very Bad mpg need help
    Dec 2012
    grand rapids
    Would it be cheaper to buy all the from home depot
    Or the alreadyade kit from autozone??
bad, mpg
