Thread: car rpm's acting weird after warm up and only in drive and reverse
Results 1 to 3 of 3
  1. #1 car rpm's acting weird after warm up and only in drive and reverse
    SE Level Member 2000supercharged's Avatar
    Aug 2012
    unitedstates
    last couple days i let my car warm up in the morning ( like your supose to ) and it idles fine in park while it warms up. once you put it in drive or reverse it wants to die like today i put it in reverse and it just idle down and killed itself ? and sometimes when i drop it drive and the rpms drop to like 300 and go up to 1000rpm's and it repeats itself and then it does that until i rev it and but if i dont rev it, it dies for some reason. But once i rev it and drive it down the street (already at running temp) it runs perfect. it never does any other time except in the morings (when im letting warm up) and getting ready to go school once i put it in drive or reverse it does the idle surgring ( jumping from around 300 to around 1000 rpms) any suggestions ? i just want my car to run right i know i have a exhaust leake from the Y pipe on pace setter headers but wouldnt think it would cause that only in reverse or drive ?
  2. #2 Re: car rpm's acting weird after warm up and only in drive and reverse
    Omaha, NE
    Exhaust leak pre-upstream o2 sensor is probably the cause.
  3. #3 Re: car rpm's acting weird after warm up and only in drive and reverse
    Aug 2012
    unitedstates
    okay well thats where my exhaust leak is on the pacesetter's i was going to pull them this coming spring when it gets warmer and weld all the way around it to make a good seal
  1. irratic idle in drive while warm
    By Lord4play in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2011, 09:52 PM
  2. Transmission acting weird during startup
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2011, 11:09 PM
  3. please help tranny acting weird
    By ryan88z in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 09:17 PM
  4. Forums Acting Weird
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-29-2008, 08:03 AM
  5. Help please!!! Electrical system acting weird, Car won't start now!!
    By Tkuligowski in forum General Tech Discussion
    Last Post: 01-24-2008, 08:42 PM
