Thread: 2005 GP little to no heat... and its winter
Results 1 to 16 of 16
  1. #1 2005 GP little to no heat... and its winter
    Jan 2013
    United States
    Firstly Hi everyone I'm not a GP owner, but my mother is and right now shes freezing in this below 30 degree temps we are having.
    Shes got a 2005 grand prix (base), the fan controls work on low to high, but the problem is only a little bit of heat comes out and its when the fans are barely blowing, as u ramp up the speed the temp drops fast. I changed the thermostat, and did a flush and still wasn't fixing it. There was dexcool coolant used but its fairly new in the system (last flush was in 2010). I touched the coolant lines and the ones that run into the firewall and they are all nice and warm with no temp differences. But the heat won't blow or work inside the cabin. So which leads me to believe something in the dash has failed.
    Any ideas as to what it could be? Should I try blowing air into the heater core hoses and see if that cures anything? Any links or DIY for removal of parts or testing of parts will be GREATLY appreciated since I'm clueless on GM cars.
    I live here. DirtDog's Avatar
    Jun 2012
    Have u opened the bleeder screw o. Top of the thermostat to bleed the air outta the system? It also could be the blend door actuator that controls warm or cold air I believe
    Sent from my DROID RAZR using Tapatalk 2
  3. #3 Re: 2005 GP little to no heat... and its winter
    Destroys cars izup69's Avatar
    Iowa
    Quote Originally Posted by marines542 View Post
    I would really check that. Haveing replaced my hole cooling system on my 06. alot of the time there is just air stuck in the heater core. May take a-while to bleed out the air. Just recently I replaced the water pump on my moms chevy malibu. I thought I had the system bleed turned the heat on and got cold air. Opend the bleeder valve back up and it spit air out for about 2 min. strait. After that had all the warm air I could handle. Sometimes its a pain to bleed.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  4. #4 Re: 2005 GP little to no heat... and its winter
    Since the flush was done and you aren't hearing gurgling or seeing unusual engine temps, it sounds like the cooling system is good.
    I'd look to the blend door actuator. Look for full movement within 45 seconds of you changing the temp from low to high or vice versa.
  5. #5 Re: 2005 GP little to no heat... and its winter
    Jan 2013
    United States
    how do I get access to this, I believe this might be a issue. I dont notice nothing changing lol
  6. #6 Re: 2005 GP little to no heat... and its winter
    Nov 2012
    Madison
    Quote Originally Posted by GreekPower View Post
    might get you in the ballpark
    http://www.grandprixforums.net/blend...ent-21941.html
  7. #7 Re: 2005 GP little to no heat... and its winter
    The reason for my vagueness is I've never gone near one of that year. Otherwise I'd have a detailed write up with pics for you.
  8. #8 Re: 2005 GP little to no heat... and its winter
    Nov 2012
    Madison
    Bill do you have any how-to Vids up anywhere....?
  9. #9 Re: 2005 GP little to no heat... and its winter
    Spazz search on the word "e asy" without the space and my name.
  10. #10 Re: 2005 GP little to no heat... and its winter
    Nov 2012
    Madison
    I know Bill, I always grab them for my curious mind.
    I meant like You Tube-able ... miniseries stuff ya know.....
  11. #11 Re: 2005 GP little to no heat... and its winter
    May 2008
    Schuyler, NE
    I'm a little confused as to what your issue is here. Is it a lack of airflow, or just cold air?
    Jun 2012
    A lack of heat from air vents
  13. #13 Re: 2005 GP little to no heat... and its winter
    May 2008
    Schuyler, NE
    Does that mean a lack of airflow, or cold air is coming out?
    Jun 2012
    Cold air coming out. Read the post
  15. #15 Re: 2005 GP little to no heat... and its winter
    May 2008
    Schuyler, NE
    This is what has me confused. Is it not blowing, or is it cold air?
    Jun 2012
    O I see now. Maybe he'll clarify when he gets on next
  1. winter heat
    By dlk in forum General Grand Prix Discussion
    Last Post: 11-06-2012, 05:55 PM
  2. Replies: 3
    Last Post: 02-15-2012, 05:23 PM
  3. Car has no heat! And winter is here....
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-17-2011, 04:00 PM
  4. Winter Mode, Heat Exchanger Blockoff
    By 2003 SSEi in forum Visual/Body Modifications
    Last Post: 12-20-2010, 09:00 AM
  5. Alternate Heat Source for this winter?
    By kalbracht in forum Off Topic Discussion
    Last Post: 10-27-2010, 10:16 PM
