Thread: Analog to Digital DIC Conversion Question
Results 1 to 2 of 2
  1. #1 Analog to Digital DIC Conversion Question
    Jan 2013
    clinton twp. mi
    Ok so I did this conversion a couple of weeks ago everything works fine except it does not give me the range or avg mpg the oil life and fuel used works the only wire i did not hook up was the light blue which everything i have read tells me i do not need this wire as i do not have the heads up display. I have a 99 se and the dic came from a 00 gt any help would be great
  2. #2 Re: Analog to Digital DIC Conversion Question
    Donating Users
    Sep 2012
    LI, NY
    I would re-check these 2 connections/splices:
    First-the tan wire you need to splice into the tan wire that is on the DLC(Data Link Control/
    Diagnostic Plug). I did not cut the wire, I used a crimp on splice connector.
    Then- the dark green wire for the VSS (Vehicle Speed Sensor) you need to splice into the dark
    green wire on the back of the speedometer. There are a few dark green wires. Mine was the second in next to a greyish brown wire.
    In all the wiring schematics that I have seen, the functions that these 2 wires control are not specified. All the other wires show which functions they control.
  1. Analog to digital DIC
    By Logan541 in forum General Tech Discussion
    Last Post: 09-13-2012, 03:27 PM
  2. Analog to digital DIC
    By 7point62 in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2012, 07:48 PM
  3. Analog DIC to Digital DIC
    By selym17 in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2012, 09:03 PM
  4. Analog DIC to Digital DIC
    By selym17 in forum General Tech Discussion
    Last Post: 03-01-2012, 02:35 PM
