Thread: blower motor speed selection
Results 1 to 8 of 8
  1. #1 blower motor speed selection
    trenton, on
    hi all,
    my o3 grand prixs blower motor works only in speed selections one to four, but will not run in position 5(hi speed).
    would it be the control head or the resistors. Also, does anyone know where the resistors are found.
    thanks in advance.
    John paul
  2. #2 Re: blower motor speed selection
    Nov 2011
    NY
    Have you checked the fuse block before you go crazy? I lost speed #5 and it was a fuse... Just saying.
  3. #3 Re: blower motor speed selection
    trenton, on
    Quote Originally Posted by coolone View Post
    thanks for the reply coolone. good suggestion, i'll check that first. it's the easiest part to check in minus 20 degress!!
  4. #4 Re: blower motor speed selection
    SE Level Member GTPonNOS's Avatar
    Dec 2012
    White Bear Lake MN
    My heater blower quit all together after hitting the final carwash at 10 degrees out. It was not reacting well ahead of that to passanger - driver adjustments and never seemed to go on Max. I need to roll up my sleves and warm up the shop, any suggestions would be nice!
  5. #5 Re: blower motor speed selection
    Panama City Beach, FL
    Blower motor resistor. Enjoy the North, cubbies.
  6. #6 Re: blower motor speed selection
    Jan 2013
    clinton twp. mi
    The resistor is located underneath the glove box behind the blower motor they are a pain to get to.
  7. #7 Re: blower motor speed selection
    Dec 2012
    White Bear Lake MN
    Thanks all! I had washed the car before putting it away for the winter and it was zero out. I got in a warm shop and all is working fine now! I am still the luckiest guy on the planet!!!
  8. #8 Re: blower motor speed selection
    trenton, on
    Quote Originally Posted by Familyman View Post
    hi Familyman, thanks for the reply, you weren't kidding when you said it was a pain to get to!! i'll atempt the removal when it isn't so brutally cold out here. thanks again, much appreciated.
    Cheers,
    john paul
  1. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  2. Blower Motor or Blower Motor Resistor???
    By soverstreet4472 in forum General Tech Discussion
    Last Post: 10-08-2012, 06:50 PM
  3. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  4. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  5. Stumped. Blower motor works on speed 5 *UPDATED*
    By alpine2g in forum General Tech Discussion
    Last Post: 09-29-2009, 05:43 PM
