Thread: Any help with the Class 2 data line(please i beg of someone)
Results 1 to 1 of 1
  1. #1 Any help with the Class 2 data line(please i beg of someone)
    Yoga city
    ok so im looking at the u1301 dtc,High voltage on the class 2 serial data circuit. so im looking at a diagram and its pin #25 l-BU. im trying to check for interment connection. Is the other end on the dlc? pin number 2 pu? this is driving me nuts its back and not going away.
    And the code is read when reading the abs codes, u1301 so which wire on this here diagram you think i should check? everything on ebcm or go from splice pacK
  1. Where does this wire go?
    By fromne in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2012, 05:21 PM
  2. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  3. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  4. TXL wire necessary?
    By Toasty in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2009, 12:18 PM
  5. What's this wire for?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 08:00 PM
