Thread: Tools/Materials needed for trans fluid change and filter change
Results 1 to 18 of 18
  1. #1 Tools/Materials needed for trans fluid change and filter change
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Hey guys, i think now at 71k miles is about a good time to change my trans filter and fluid. does anyone have some advice on how to go about it and what materials and tools ill need? What fluid should i buy and how much is required? Thanks
  2. #2 Re: Tools/Materials needed for trans fluid change and filter change
    antioch ill
    15 gallons of dex 3 and a shop rag will be good for a filter have fun at it oh and for tools use the jocks from school
  3. #3 Re: Tools/Materials needed for trans fluid change and filter change
    you need 8 quarts of trans fluid, a new filter, car ramps or jack stands, and a 10 mm socket iirc.
    and a large drain pan. and a can of brake cleaner to clean the stock gasket and the pan. re use the stock gasket.
  4. #4 Re: Tools/Materials needed for trans fluid change and filter change
    antioch ill
    ^what he said
    Ohio
    Scott has everything right.
    10mm socket.
    Very large drain pan(big glad ware container works best)
    2 gallons or 8 quarts of dex 3 or 6...you may not use all 8 quarts.. You may use around 7-8. All depends on the tranny.
    Jack stands or ramps.
    Filter.
  6. #6 Re: Tools/Materials needed for trans fluid change and filter change
    Nov 2011
    Indiana
    Sweet thanks alot
  7. #7 Re: Tools/Materials needed for trans fluid change and filter change
    Nov 2011
    Indiana
    Does dex 3/6 matter?
  8. #8 Re: Tools/Materials needed for trans fluid change and filter change
    antioch ill
    Ive been told by many 6 is better
  9. #9 Re: Tools/Materials needed for trans fluid change and filter change
    Omaha, NE
    Don't forget to check the filter box before you leave the store for a gasket, sometimes they "forget" to include them.
  10. #10 Re: Tools/Materials needed for trans fluid change and filter change
    i'd stick with what the trans calls for, if it supposed to use dex 3, use dex 3.
    dex 6 is thinner i've heard.
  11. #11 Re: Tools/Materials needed for trans fluid change and filter change
    GTP Level Member AjL227's Avatar
    IL
    Just use Dex 3. There is no reason to "upgrade", why spend more $?
    In the end, the fluid is not what will make or break your transmission when the torque hits.
    3/8" drive 14.4V cordless drill and a 10mm shallow/deep gets the job done in minutes.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  12. #12 Re: Tools/Materials needed for trans fluid change and filter change
    Nov 2011
    NY
    Get a large but shallow plastic container or pan, 10 bucks or so at Kmart, Walmart. You modded? Might want to consider using a shift kit if you've been thinking about it. If not is ok too.
    What's the condition of the fluid now? Red still? Brown?
    When you unbolt the pan, work towards one corner without fully removing the pan and allow the fluid to drain out to the plastic container some. Try to get the pan off without much moving around so when it's down you can just look around in the pan for anything unusual. The magnet in the corner of the pan will have small fine particles (black) which is normal. You don't want to see metal pieces though. If the gasket is original, the reusable rubber gaskets are better, just clean the old gasket off, don't be afraid, clean it good for the new gasket, do the surface of the tranny where the pan attaches as well.
    I don't remember the torque spec for putting the bolts back, but seat the bolts + 1/4 turn should be good. Once all the bolts are tightened, put at least 6 quarts of fluid back... 7 is ok too just go slow and check the dip stick when 6-1/2 quarts are in and slowly add. You must bring tranny up to temp as well to fill accurately with final top off. This means filing close and driving a little, maybe around the block a bit, shifting through gears and such. Then checking and filling until correct.
    Just a word on the tranny fluid, it's SLIPPERY stuff, lol, try not to spill it.
  13. #13 Re: Tools/Materials needed for trans fluid change and filter change
    Nov 2011
    Indiana
    Do all filters come with a gasket? Wouldn't that be the manufacturers problem if there isn't one? And ill prolly go with Dex three then just so I don't mix and match the fluid. And thanks coolone for that write up, very helpful
  14. #14 Re: Tools/Materials needed for trans fluid change and filter change
    i used a dura last filter, it came with a gasket, but its best to reuse the stock gasket, if its in good shape. you will notice a big difference between the 2.
  15. #15 Re: Tools/Materials needed for trans fluid change and filter change
    Nov 2011
    Indiana
    I just checked the dipstick. The color of it looked like a rust. Not brown and not bright red. In between I'd say. And both of the indicator holes had oil in them. Wasn't thick n covered fully but they had oil in both so idek if I should do trans maintenance.
  16. #16 Re: Tools/Materials needed for trans fluid change and filter change
    at 71,000 miles your only like 20,000 over due. get to it before you really cant service it. your fluid should be red to pink looking. not brown, or light brown. shades of red only lol
    just drop the pan, change the filter, fill it back up. do it again in 50,000 miles. some say every 30, but that seems to over kill in my book.
  17. #17 Re: Tools/Materials needed for trans fluid change and filter change
    Nov 2011
    Indiana
    For some reason 75k miles was stuck in my head for trans fluid...alright i will this upcoming break in between semesters in a week. FINALS!!!
  18. #18 Re: Tools/Materials needed for trans fluid change and filter change
    Torque on the bolts is 120 inch lbs aka 10 ft lbs
  1. How much Fluid for Trans Filter Change
    By dhdolphns in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2011, 03:48 PM
  2. 2004 Grand Prix Trans filter/fluid change. HELP!!!
    By frtaylor9 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2011, 09:46 PM
  3. 2004 Grand Prix Trans filter/fluid change. HELP!!!
    By frtaylor9 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-26-2011, 07:35 PM
  4. 2004 Grand Prix Trans filter/fluid change.
    Last Post: 03-26-2011, 06:07 PM
  5. Hardshifting after new fluid and filter change.
    By Pontiacman76 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:47 PM
