Thread: Put 18.14 gallons in tonight?
Results 1 to 20 of 20
  1. #1 Put 18.14 gallons in tonight?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    I'm sure there is a reasonable explanation for this but just got done with a long trek and filled up. DIC said I spent 16.6 gas pump said I put in 18.14. Someone is lying to me!
    Although I must say my milage has been off since I put new tires on. Figured that was due to them being slightly taller then the old set though. On this tank I made it 411 miles and DIC said I averaged 24.4 when normally on this kind of trip it should have been more like 26-28. Any thoughts?
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Put 18.14 gallons in tonight?
    antioch ill
    thats weird becuase our gas tannks are like 16.8 gallons so im guessing the dic is right
  3. #3 Re: Put 18.14 gallons in tonight?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by Matt Palm View Post
    My 1997 GTP tank is 18.0
    1997 Red GTP 182000 miles stock
  4. #4 Re: Put 18.14 gallons in tonight?
    SWPA
    Quote Originally Posted by h0wl0ngcanitbe View Post
    What size tires are you running?
    I know when my brother had his lifted Jeep the tripometer would register 1.1 miles for every true mile driven. That's a little extreme example considering the upping in tire size he had, but its an example.
    Also I could see putting an extra gallon in the neck. If you were way low it is possible to put 18 gallons into a 17 gallon tank.
  5. #5 Re: Put 18.14 gallons in tonight?
    Marysville WA
    Well I know we have 18 gallon tanks, my new tire size is the same as most of us run 245/45/18 I know I was low just cause I drive a lot and just kinda know where the tank is at. Unfortunately my gas gauge has been broken since I purchased the vehicle (Heh one of those things ya just never test when buying a car) so I have always relied on the Trip and the DIC.
    I figured some may have back logged into the neck, but its just really close. And as far as the mileage being off, I was getting 450 a tank and now based on the numbers I posted there is no way im getting 450 a tank.
    Hrmmmmm.....
  6. #6 Re: Put 18.14 gallons in tonight?
    GT Level Member jake91's Avatar
    Jun 2012
    mesa az
    mine is always 1 gallon off when i fill it
  7. #7 Re: Put 18.14 gallons in tonight?
    Your first mistake is thinking a gauge is super accurate. It's not..it's a relative idea. Second is knowing you modified something w/o changing the calculation that the pcm uses to calculate things.
    A + B will never equal C if you change B to D
  8. #8 Re: Put 18.14 gallons in tonight?
    SWPA
    Hrmmmmm.....
    245/45/18 isn't any taller than stock so your mileage is correct. And your mileage will suffer due to the winter mix of gas as well as cooler temps.
  9. #9 Re: Put 18.14 gallons in tonight?
    Marysville WA
    Well I know gauges are never near accurate its just non of the math equates either from the DIC or literally.
  10. #10 Re: Put 18.14 gallons in tonight?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    For less time that this whole fuel level inquiry has taken you could have fixed the fuel gauge that hasn't worked since you have owned the vehicle...
    Go through trunk, pull fuel accses hatch and install new float/sending unit on bucket.
    It's on the 97 right...ask me how I know lol
  11. #11 Re: Put 18.14 gallons in tonight?
    Jan 1970
    Maquoketa, Iowa
    He'll have to pull the bucket anyway when the fuel pump burns up from running the tank so low
  12. #12 Re: Put 18.14 gallons in tonight?
    Marysville WA
    Quote Originally Posted by 231FUN View Post
    Go through trunk, pull fuel access hatch and install new float/sending unit on bucket.
    I looked into and the only teaching tool I found was for a Bonnie and the process seemed really complicated. I thought the fuel tank access was under the rear passenger seat. Ill check it out and see if I can replace that float. Regardless I am curious about the math cause obviously its really off.
    And I usually let the tank run to 16 and then fill im pretty religious about that as I dont want the fuel system to get screwed up. Thats why im wondering about everything. I drive more then most trust me, so im pretty in tune with my car well when it comes to gas anyways. So believe me I was more then surprised when I saw that I put in 18+ gallons in.
    If anyone has more on that fuel gauge fix please feel free to post up
  13. #13 Re: Put 18.14 gallons in tonight?
    I live here. TLSheff's Avatar
    And I feel bad if I go more than 14.5 gals on a fill up. Holy Crap.
  14. #14 Re: Put 18.14 gallons in tonight?
    Marysville WA
    Well when you drive like I do ya space it out, this week ive logged 800 miles, and its only Thursday...
  15. #15 Re: Put 18.14 gallons in tonight?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Im with Sheff, filling up anything over 15 gallons and im like Whaaaaat? O_o
  16. #16 Re: Put 18.14 gallons in tonight?
    Portland Oregon
    Where do you go? I'm in the Portland area. I could possibly help you with the swap. I might even have a fuel float assembly you can use
  17. #17 Re: Put 18.14 gallons in tonight?
    Nov 2010
    Ray MI
    16.8 is a full tank + the fuel neck. I ran my car down to what I thought was bone dry turns out I still had about 2 gallons left in the tank.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  18. #18 Re: Put 18.14 gallons in tonight?
    Marysville WA
    Quote Originally Posted by OH4CompG View Post
    Im in real estate and I drive up and down Puget sound all week long, I sell bank owned homes so im pretty busy.
    Update on the fuel situation or rather info on todays fill up
    DIC said I spent 15.1
    I put in 15.12
    372 Miles on the Trip
    DIC said 24.5mpg
    I guess this thing has a mind of its own
  19. #19 Re: Put 18.14 gallons in tonight?
    Marysville WA
    Trust me dude when you put in three tanks in one week ya gotta space out the fills.
  20. #20 Re: Put 18.14 gallons in tonight?
    SWPA
    My DIC is never right on MPG. It's a calculation based on driving conditions. Its not based on miles driven per gallons used.
  1. Hours Per Gallon/Gallons Per Hour
    By Chad Gervais in forum General Grand Prix Discussion
    Last Post: 08-26-2012, 08:38 PM
  2. Fuel Capacity 5 Gallons SHORT! Anybody know WHY?
    By Autoworks in forum General Tech Discussion
    Last Post: 06-04-2012, 08:50 AM
  3. Fuel tank is 12-13 gallons?
    By Xanthous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2011, 11:41 AM
  4. how many gallons are our tanks?
    By k5greek in forum General Tech Discussion
    Last Post: 12-20-2010, 12:54 PM
  5. Where I'll be tonight...
    By Reflective Concepts in forum Off Topic Discussion
    Last Post: 05-02-2009, 11:00 AM
