Thread: "Front right turn signal out" then comes back
Results 1 to 8 of 8
  1. #1 "Front right turn signal out" then comes back
    SE Level Member Scott Gerhart's Avatar
    Aug 2012
    Reading, PA
    My turn signal blinks fast and I get the message on the display that says "front right turn signal out" on the display but then it starts to work again minutes later. Has anyone experienced this issue?
  2. #2 Re: "Front right turn signal out" then comes back
    St. Louis
    Try removing the bulb and cleaning the contacts in the base. Might just be some corrosion in there.
  3. #3 Re: "Front right turn signal out" then comes back
    Oct 2011
    Toledo, OH
    I'd change the bulb anyway since that sounds flakey, clean the contacts and use dielectric grease. Pretty sure the turn signals are computer controlled. When my front left burned out and I got that message, it STILL flashed fast even with a new bulb in, until I turn off the car and restarted it.
    7"
  4. #4 Re: "Front right turn signal out" then comes back
    i had a similar problem. turned out to be the DRL module.
    Aug 2012
    Reading, PA
    I plan to change the bulb, clean the contacts, and use some dielectric grease but in case that doesn't work do you know a part number for the DRL module? Are you referring to a fuse?
  6. #6 Re: "Front right turn signal out" then comes back
    Scott G.. what year/model do you have? You likely don't have a DRL module in the car, if it's the year I think it is.
    Aug 2012
    Reading, PA
    2004 Grand Prix
  8. #8 Re: "Front right turn signal out" then comes back
    found this, it seems like it the drl may live behind the fan blower motor. Drl location 2006 grand prix - FixYa
  1. Went back to "stock" lookin tail lights...
    By TheYanz in forum Visual/Body Modifications
    Last Post: 07-26-2012, 01:29 AM
  2. How bad is it to run 12" rotors, Front & Back?
    By Incomudrox in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2008, 06:59 PM
