Thread: Disable Park Cutout Switch??
Results 1 to 7 of 7
  1. #1 Disable Park Cutout Switch??
    Jan 2012
    Boise ID
    I have a problem with the switch in my gear shift. Sometimes I turn off the car and try to restart. I have to mess with the gear shift just to get it to start. I would like to find the easiest way to disable the switch since it is malfunctioning and isn't really needed. Thanks guys.
  2. #2 Re: Disable Park Cutout Switch??
    SWPA
    Put it in nuetral if you are having trouble starting it in park. Problem solved.
  3. #3 Re: Disable Park Cutout Switch??
    The switch is located on the transmission. Check to see if it's aligned properly. For the info on how to align it.. look up a post by me about doing an external switch on an internal switch transmission.
  4. #4 Re: Disable Park Cutout Switch??
    Jan 2012
    Boise ID
    I tried to start in neutral and it still didn't work. I will look up the alignment of the switch and go from there. More info would be appreciated. Thanks.
  5. #5 Re: Disable Park Cutout Switch??
    Not sure how much more I can do to help you.
    http://www.grandprixforums.net/how-a...ion-49297.html
    There is a dot that you can barely see that needs to be lined up with the line on the switch when the selector is in neutral. Otherwise..you'll also find in that link the wiring schematic that would tell you how to bypass it. Although I don't suggest doing that.
  6. #6 Re: Disable Park Cutout Switch??
    Jan 2012
    Boise ID
    Thank you for the help.
  7. #7 Re: Disable Park Cutout Switch??
    Did that fix the issue?
  1. Electric cutout switch location??
    By joshv in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2011, 05:42 PM
  2. Trip Computer, HVAC Controls, Ignition Switch, Park Lock Solenoid
    By Bart40th in forum General Tech Discussion
    Last Post: 11-08-2011, 12:57 PM
  3. Won't Shift Out of Park (sometimes)... Ignition Switch?
    By GTFiske in forum General Tech Discussion
    Last Post: 01-12-2011, 12:53 PM
