Thread: Battery Life
Results 1 to 20 of 22
  1. #1 Battery Life
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Hi all,
    Just wondering what the average user can expect out of the original battery in a grand prix. My GP is a 2004 made in 7/2003 and now has over 220k. I still have the original AC Delco battery. I work in an auto parts store and I have people come in daily with a variety of makes/models with failed batteries as little as 3 years old. We sell Exide and our longest warranteed battery is 9 years.
    As a side note, Im not having any charging/starting problems right now, but the northeast is expecting a cold winter, would it be wise of me to get a new battery now to be on the safe side, considering my battery is almost 9 years old and is only rated for 680 CCA? (The one im looking at at the store is rated 770 CCA.)
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  2. #2 Re: Battery Life
    Wouldn't trust the mid range exides.
    Cheapest or most expensive lines only.
    What I would do is test your battery, you sell them, so you should have a tester.
    770 CCA sounds like the mid range line, I'd suggest avoiding them.
  3. #3 Re: Battery Life
    Sep 2012
    Bangor, ME
    Why not the mid range line?
    GOD BLESS...
  4. #4 Re: Battery Life
    Seem to warranty more of those than the cheaper ones.
    Heard that the Exide rep mention they were worse in terms of durability because they sacrificed that, for cranking power. Note the batteries in the next line up have the same or less CCA.
    Their latest flat cell AGM looks interesting.
  5. #5 Re: Battery Life
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    test it, if meets specs why replace?
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  6. #6 Re: Battery Life
    Jul 2012
    Chicago
    You sure are lucky.. My 2003 Bonneville built in May of 2003 is on its 3rd battery.
    -Carl
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Original AC Delco batteries are typically the AGM (glass matt) they tend to last much longer then aftermarket liquid style.
    We build all the local police and sheriff vehicles majority of them run 2 yellow top optimas because of the abuse. But they are pricey and ive seen those come back after just a few months..
    I just finally replaced my agm factory battery and just opted to go with a Everstart Maxx its 800cca.
    From my past experience I've seen new batteries go bad and I've seen batteries last for years. there istt really much rhyme or reason just kinda hit or miss.
    You can take your car up and have a load test done on it to check it out. But my factory batt was testing about 50-75ca lower then spec so I wasnt waiting for a snowy freezing Michigan morning to have a no start condition
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  8. #8 Re: Battery Life
    Quote Originally Posted by rperry435 View Post
    For the 04+, that is correct.
    For the 97-03, not so much.
    I replaced my factory battery (2002) last fall after not having driven or started the vehicle for a week. It wouldn't start. Tried charging, still wouldn't start.
    The previous winter it was a little slower to crank over, but it always started.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    I bought an optima red top and love it. Can't get the thing to die no matter what i do.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  10. #10 Re: Battery Life
    Sep 2012
    Bangor, ME
    As a follow up to the original question. Assume this battery is in fair/good condition. How long can i safely run the radio with the engine off before the battery is drained to the point of not starting?
    I was going to load test it at work but our tester is broken right now.
    GOD BLESS...
    Oct 2011
    MI
    Yeah I always forgetz when responding not everyone owns a 04+
  12. #12 Re: Battery Life
    Im my experience if you drive the car each day for say 15 minutes or so, the battery can go well past it's expected life. If you drive the car occasionally or infrequently, you will find the battery life is much shorter.
  13. #13 Re: Battery Life
    Pennsylvania
    04+ factory batteries last about six years.
  14. #14 Re: Battery Life
    SWPA
    I wish that were the case. I replaced my factory battery in my 07 at the beginning of this year.
    May 2011
    United States
    Thats still 5 years. Thats not bad.
    Sent from my Droid
  16. #16 Re: Battery Life
    Pennsylvania
    Yeah. "About."
    Actually... an '07... possibly built in '06. Check dat vin.
  17. #17 Re: Battery Life
    Yeah..find your car's born on date and you'll likely find...it's 6 or more.
  18. #18 Re: Battery Life
    Sep 2012
    Bangor, ME
    Like mine. Its a 2004, but the door jamb sticker says it was made in July 2003.
    GOD BLESS...
    Oct 2011
    MI
    Thats exactly right too. Its rather amusing when someone says.. well I drive the car one every couple of weeks....I just bought that battery x number of year(s) ago I dont know why its no good
    Oct 2011
    MI
    Quote Originally Posted by Chadgervais View Post
    Typically anything after the 6th month it becomes the next year model.
    Edit.. whoops sorry bill didnt see u said that
  1. oil life
    By tegbir in forum General Tech Discussion
    Last Post: 09-10-2012, 08:43 PM
  2. Oil Life
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2010, 07:32 AM
  3. tranny life
    By CHAMPS97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2010, 03:03 PM
  4. oil life?
    By banzai7 in forum General Tech Discussion
    Last Post: 07-11-2009, 12:40 AM
  5. Cant find these for the life of me???
    By chevyy1212 in forum Visual/Body Modifications
    Last Post: 05-08-2009, 07:46 AM
