Thread: Oil Life
Results 1 to 7 of 7
  1. #1 Oil Life
    SE Level Member mlasnoski's Avatar
    Jun 2010
    Marquette, Michigan 49855
    Hey All,
    I have a 04 GTP CompG. Question to you is: Do you guys use the oil life monitoring system on your cars or do you still recommend replacing it every 3,000 miles? I've only put 3900 miles since May, when I bought it. Just wondering what your thoughts were on it. I do live in an area where there are many hills.
    Just wanted some input.
  2. #2 Re: Oil Life
    Charles City, IA
    I believe synthetic shield an older member here did some research on it and found them to be pretty accurate. I know on our g6 it read 0% just a month before it was do for its yearly change of amsoil.
    SMGPFC Two Nipple General
  3. #3 Re: Oil Life
    Jun 2010
    nice. Oh hey 01GTP, I pm'ed you about the Amsoil. I'd like to switch to either that or Mobil 1, but I first must see if I have an oil leak...grr. The intake was already replaced before I bought the car because of coolant leaking. I see oil seepage on the right side above the transmission... I'm not pleased. On a positive note, my oil level is full. =)
  4. #4 Re: Oil Life
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    dont be lazy. just open up the hood and check the dipstick. I have never ever gone of how many miles are on the oil. I dont do that because it is not how many miles your drive, it depends on the type of driving that you do. I have seen highway vehicles go an easy 4000 miles and when you check the dipstick for the color of the oil that it is still almost factory clean.
  5. #5 Re: Oil Life
    like me i drive 90% city, my top speeds are around 45-50 and stop and go. Both my jobs are only 3-4 miles from home. My car will never even reach 180* with these trips and my oil shows wear.
    I can go only about 2200 miles and the oil is very bad shape.
  6. #6 Re: Oil Life
    Jun 2010
    Nice! I checked mine today, in fears of this oil seepage I hope I don't have. Perhaps its just my imagination and old stuff from when the valve covers leaked...but I'll find out Friday.
    My oil level was fine and the color still looked new.
  7. #7 Re: Oil Life
    oil analysis is the only accurate way to be 100% sure if your oil is okay or in need of changing.
  1. pcm/oil life monitor ???
    By Jakegday in forum General Tech Discussion
    Last Post: 04-17-2010, 08:32 PM
  2. The love of my life...
    By MizzBecca in forum Off Topic Discussion
    Last Post: 01-08-2010, 02:37 PM
  3. oil life?
    By banzai7 in forum General Tech Discussion
    Last Post: 07-11-2009, 12:40 AM
  4. You can never have to much Rush in your life
    By GeddyLee in forum Off Topic Discussion
    Last Post: 06-19-2009, 01:58 PM
  5. Cant find these for the life of me???
    By chevyy1212 in forum Visual/Body Modifications
    Last Post: 05-08-2009, 07:46 AM
