Thread: 98 gtp starting problemsy
Results 1 to 18 of 18
  1. #1 98 gtp starting problemsy
    SE Level Member chuckbattams's Avatar
    BRANTFORD, ONTARIO
    My gtp starts runs for 5 seconds then quits. Where do I start???
  2. #2 Re: 98 gtp starting problemsy
    fuel pump resistor
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Yup. Either get a new one or just cut it out and solder/connect the wires together. :thumbup:
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #4 Re: 98 gtp starting problemsy
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    fuel pressure regulator
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  5. #5 Re: 98 gtp starting problemsy
    BRANTFORD, ONTARIO
    Thanks guys, will be on it in the morning, learned its under the passenger front fender.
  6. #6 Re: 98 gtp starting problemsy
    Pull the resistor out of the fuse box and bend out tab 85 or whichever one it is and put the resistor back in.
  7. #7 Re: 98 gtp starting problemsy
    LOL... Dan means..pull the fuel pump speed relay out of the underhood fues box and bend out tab 85 so it won't hit anything. Problem fixed.
    When GM fixes the resistor. They leave the original one where it is and put the new one in the middle of the firewall behind the motor.
  8. #8 Re: 98 gtp starting problemsy
    Bill knows what I mean lol
  9. #9 Re: 98 gtp starting problemsy
    Which is why I'm going to make you find the picture for him.
  10. #10 Re: 98 gtp starting problemsy
    I'm on my phone right now I can't lol
  11. #11 Re: 98 gtp starting problemsy
    I gotta do everything
  12. #12 Re: 98 gtp starting problemsy
    Thanks bill you're the bestest
  13. #13 Re: 98 gtp starting problemsy
    BRANTFORD, ONTARIO
    Thank you gp'rs. I was just talking with the wife this morning,she told me the car will not start anymore I will be home Thursday, so I will do the tab bending then, I assume it is a short term fix till I get a new one,right?
  14. #14 Re: 98 gtp starting problemsy
    Nov 2012
    illinois
    your gas mileage will drop drastically.
  15. #15 Re: 98 gtp starting problemsy
    Quote Originally Posted by hammygtp View Post
    it will, never heard this one before.
    bending the tab puts the pump in high speed mode, the engine cant take more fuel then it wants, so not like its getting over fueled.
    people here have just left it like that for ever, me, i'd get a new resistor just to be safe, and not burn the fuel pump up possibly.
  16. #16 Re: 98 gtp starting problemsy
    BRANTFORD, ONTARIO
    that's alright Scottydoggs, I replaced it with a new/old one from my 98 1/2 ton GM truck, same numbers, and it works great.
  17. #17 Re: 98 gtp starting problemsy
    Akron Ohio
    MPG will NOT DROP! Ive done this too!
  18. #18 Re: 98 gtp starting problemsy
    ANNNNNNT try again. I currently get 23mpg driving 20 miles each way to work and doing 80mph doing that stretch. Otherwise I'm all around town. If you were correct, then my mileage should shoot up to say 40mph if I fixed my resistor.
    The pressure regulator dumps the extra fuel back into the tank and most fuel pumps in the majority of cars out there run full time. There is a slight difference in programming of running the pump full power vs partial, but your pcm will take care of that for you if you don't retune the car.
  1. 97 gtp not starting
    By billysmth555 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2011, 02:04 PM
  2. starting to mod
    By LeThAlREMiX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 08:38 AM
  3. Just Starting!
    By fpgt17 in forum Introductions/Noob Questions
    Last Post: 01-17-2011, 01:01 PM
  4. gtp not starting
    By mtz956 in forum General Tech Discussion
    Last Post: 12-04-2010, 07:46 PM
  5. Starting to Mod
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 05:04 AM
