Thread: Performance Shift
Results 1 to 10 of 10
  1. #1 Performance Shift
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    Can you put a Performance Shift Knob in a GP that doesnt have one?
  2. #2 Re: Performance Shift
    Yes.
    But its already "built into" the pcm on 01+ cars that dont have the button.
    I think there is a thread that shows you what you can do to put on in.
  3. #3 Re: Performance Shift
    I have one i'd sell if you're interested.
  4. #4 Re: Performance Shift
    Aug 2012
    Danville
    If the OP is not interested in buying your performance shifter, I would be.
  5. #5 Re: Performance Shift
    Apr 2012
    Myrtle Beach, SC
    I'm not interested there's one at the pull a part near me for like $2 so you can have it.
  6. #6 Re: Performance Shift
    Just run a wire and pin it in the PCM...it's either #23 or #26.
  7. #7 Re: Performance Shift
    Aug 2012
    Danville
    Quote Originally Posted by blueguy91 View Post
    Does that mean you don't need the switch on the shifter? The #23 or #26 pin turns it on?
  8. #8 Re: Performance Shift
    Yeah, you need a PS shift knob.
    Or put it on a toggle switch.
    Which is pretty ricey.
  9. #9 Re: Performance Shift
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    You need a re-programmed PCM with the correct Cal's for performance shift.
    You also need to run a wire from the ECU, through the shifter switch, to ground.
    Pin 21 Clear connector.
    Seems like forever ago that I figured out how to do this... heh
    The writeup from my old website:
    RivMan's Page
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  10. #10 Re: Performance Shift
    Jan 2013
    windsor, on
    Is it possible to change the shift knob in the 02 go gr, with the shift engage trigger on it?
  1. Please help Performance shift
    By sigmapi62 in forum PCM Tuning
    Last Post: 08-15-2011, 09:09 PM
  2. Performance Shift opt in GTP?
    By Vegas_Matt in forum General Tech Discussion
    Last Post: 07-26-2010, 11:27 AM
  3. Performance Shift
    By gtp02 in forum PCM Tuning
    Last Post: 05-18-2010, 10:59 PM
  4. Performance shift
    By djrepoman in forum General Tech Discussion
    Last Post: 03-15-2010, 12:36 PM
  5. Performance shift
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 10:12 AM
