Thread: Lower Engine Cover
Results 1 to 19 of 19
  1. #1 Lower Engine Cover
    Nov 2012
    Ohio
    This has to be the dumbest design ever. How do you get this thing off without removing the bumper? First person that says "it should just drop right down" dies. Help!?
  2. #2 Re: Lower Engine Cover
    Feb 2010
    TN
    Quote Originally Posted by 1filthygp View Post
    Get what thing off? Got a pic?
  3. #3 Re: Lower Engine Cover
    antioch ill
    im still alive
  4. #4 Re: Lower Engine Cover
    Yeah i have no idea what you're talking about.
  5. #5 Re: Lower Engine Cover
    Nov 2012
    Ohio
    On the underside of the car right below the rad. The engine/radiator/whatchama call it cover. I got the 3 10mm bolts no problem. The real problem is the 2 plastic "pop in" plastic bolt things. You know those stupid plastic things that you see holding interior panels together? Still with me?!?!? The lower cover has 2 of those things towards the very front of the car tucked up right in there with the lower valance and I cannot remove them because the bumper is attached to it and I don't have enough leverage to pry them loose. Best way I can describe it.
  6. #6 Re: Lower Engine Cover
    what are you taking it off for? I'm still not quite sure what you're talking about i'd have to look under my car.
  7. #7 Re: Lower Engine Cover
    Jul 2012
    Chicago
    Lower splash shield?
    -Carl
  8. #8 Re: Lower Engine Cover
    Nov 2012
    Ohio
    Quote Originally Posted by nos4blood70 View Post
    Yep. Taking it off to get to the lower radiator hose. Flushing my cooling system.
  9. #9 Re: Lower Engine Cover
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Theres a tool specifically designed for taking those clips off.
  10. #10 Re: Lower Engine Cover
    Feb 2010
    TN
    Yep boys we got us a mechanic in the house, he knows all about them whatchama call it bolt things. LOL 1filthygp I am guessing you are a noob and welcome to the boards and if you are not a noob thanks for the chuckle
  11. #11 Re: Lower Engine Cover
    take the lower hose off the engine side for ease of access to the clamp.
    either side you get off, if you put a real hose clamp back on instead of the spring clamp, it will make life easier in the long run.
  12. #12 Re: Lower Engine Cover
    I know what to get you for Christmas... a hose clamp tool
  13. #13 Re: Lower Engine Cover
    Nov 2012
    Ohio
    Took the day off today get it done. I managed to get the cover off. With one of these dollar store special!
    Anyway, Took me about 4 hours to do everything, mutiple flushes, backflush the heater core, change the thermostat and replace radiator cap.
    All is well, car runs fine and I'm alittle smarter, a redneck, yes, smarter yes.
  14. #14 Re: Lower Engine Cover
    At least you have it done now. Where do you live in OH?
  15. #15 Re: Lower Engine Cover
    Nov 2012
    Ohio
    Car heats up alot quicker and hotter. The old thermostat was on it's way out so I'll be interested in seeing what the new does for my MPG's. I live around the Mansfield area.
  16. #16 Re: Lower Engine Cover
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    One problem might be is that there are 5 bolts that hold the part in
  17. #17 Re: Lower Engine Cover
    Nov 2012
    Ohio
    Not sure I follow what your saying? 3 10mm bolts came out like butter, the plastic ones are what I pried out with the grill fork.
  18. #18 Re: Lower Engine Cover
    I have never had to go to the bottom to get the lower rad hose off, always went from the top, but I also have a one of those clamp tools. That thing is the best thing invented to remove those stupid spring clamps. And as previously stated I usually throw them away and replace them with real house clamps.
  19. #19 Re: Lower Engine Cover
    Mableton, GA 30126
    Under the car looking up just in front of the radiator the plastic part that has a lip some of them have a part that moves with springs. There are 5 bolts that hold it on you must remove all of them for it to drop down
  1. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  2. new engine cover, braces n fusebox cover
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 05-27-2010, 09:40 AM
  3. Symptoms of bad lower tranny/engine mounts
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2010, 03:40 PM
  4. lower engine mount?
    By RichCresci in forum General Tech Discussion
    Last Post: 11-30-2008, 10:47 PM
