Thread: PCM Question
Results 1 to 7 of 7
  1. #1 PCM Question
    SE Level Member Jordan Flowers's Avatar
    Dec 2011
    North Canton, Ohio, United States
    Can you put a 1998 GTP pcm into a 1997 GTP?
    If possible is there any for seen problems with this type of swap?
  2. #2 Re: PCM Question
    Jan 1970
    Maquoketa, Iowa
    97's have a oddball pcm and harness, no you cannot without swapping harnesses as well.
  3. #3 Re: PCM Question
    Dec 2011
    ok thanks
  4. #4 Re: PCM Question
    I have a 00 harness if your interested in the swap
  5. #5 Re: PCM Question
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    00 body connector is different than 97 had same issue instead of just 16 or something wires in the 97 the00 has like 40
  6. #6 Re: PCM Question
    Dec 2011
    i have a complete engine, pcm, and harness from 98 gtp
  7. #7 Re: PCM Question
    There's nothing oddball about the pcm. It is a different pcm than the 98+. Short answer is no..while the connectors will physically fit on the other pcm, the wiring pinouts are different and things simply won't work.
  1. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  2. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  3. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  4. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
