Thread: Swap 1997 GP GT engine and Tranny for 2001; Possible?
Results 1 to 7 of 7
  1. #1 Swap 1997 GP GT engine and Tranny for 2001; Possible?
    Sep 2012
    FL
    Can I put a 2001 Grand Prix GT Coupe engine and Tranny into a 1997 Grand Prix GT Sedan? Are they the same mounts etc...?
  2. #2 Re: Swap 1997 GP GT engine and Tranny for 2001; Possible?
    Trans is different
  3. #3 Re: Swap 1997 GP GT engine and Tranny for 2001; Possible?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    No tranny won't work like dsmuts said. It uses vaccum to opperate. 98+ does not. Now if you got a trans from a 97 GTP it would work. Engine will work tho.
    I went NA when a whore left -$300 in my bank account.
  4. #4 Re: Swap 1997 GP GT engine and Tranny for 2001; Possible?
    Quote Originally Posted by indygrandprix View Post
    Nope. But close.
    97-02 GTP are all 4T65e HD, non vacuum.
    98-02 GT's are all 4T65e non HD
    97 GT is a 4T60e, vacuum assisted trans. Year only.
    I say "97-02" for the previous transmissions because 03+ has some new changes.
    So basically if he wants a direct swap with no modding needed, he needs a 4T60e trans.
  5. #5 Re: Swap 1997 GP GT engine and Tranny for 2001; Possible?
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    You said eng and trans so answer is YES mounts are the same but you have to use the PCM from the 2001 as there is a lack of some wires in the fuse box you need some more wires run from the fuse box to the PCM. easy way is to use the harness from the 2001. You can call EDmorad parts for a used harness or maybe ZZP they used to sell the adapter wiring. When we did it we took the bottom of the fuse block apart and replaced the bottom section with the newer harness. A number of people have done this mainly to put a 98 or newer GTP eng/trans in the 97's. If the trans in the 97 is good you could also just change the eng.
  6. #6 Re: Swap 1997 GP GT engine and Tranny for 2001; Possible?
    Jan 2012
    Indianapolis
    What where the changes to the 03 just out of curiosity? I know it had some things different than most years but I didn't know about the trans.
  7. #7 Re: Swap 1997 GP GT engine and Tranny for 2001; Possible?
    You could do it if you wanted to add 5 wires to the pcm and have someone program the trans info in. Right now your trans in the 97 has it's pressure being controlled by vacuum. The 98+ pressure was controlled via soleniod. This is one of the noticable differences from 4T60 to 4T65.
    Add 5 wires and program. Poof..done. Been there..done that.
  1. Engine swap now tranny won't shift
    By chrisLB in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 01:27 PM
  2. need help!! with engine/tranny swap
    By Craig Ronshausen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2012, 06:49 AM
  3. 1997 GTP engine Swap
    By chi_town in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2009, 08:49 AM
  4. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
  5. 1997 Monte Engine Swap (3.1 3100 V6)
    By StreetChariot in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-25-2008, 08:06 AM
