Thread: changing rack and pinion boot 2000 gtp
Results 1 to 6 of 6
  1. #1 changing rack and pinion boot 2000 gtp
    SE Level Member john cola's Avatar
    Sep 2012
    willmar minnesota
    How difficult is it to change the rack and pinion boot on the driver's side of a 2000 gtp? mine is leaking. how hard is it to undo the rear clamp, and I assume you need to take off the tie rod end?
  2. #2 Re: changing rack and pinion boot 2000 gtp
    your rack is leaking not the boot. the boot is a dust cover.
  3. #3 Re: changing rack and pinion boot 2000 gtp
    This^^^^
  4. #4 Re: changing rack and pinion boot 2000 gtp
    Sep 2012
    willmar minnesota
    This^^^^
    speak comfort to me! I don't wanna spend $800!
  5. #5 Re: changing rack and pinion boot 2000 gtp
    well if a shop does it, it can cost up to 500 easy.
    if your up to it you can buy a new one for around 200 or less and swap it yourself.
    mine took me 4 hours to do. also did it alone, no help.
    its not horrible, but not fun either. in reality its only a 25 bolt job. its just tight to work in.
    10 bolts are lug nuts, the (2) tie rod ends bolts, 2 sway bar end links, 4 bolts that hold the sway bar in place(2 on each side), 2 bolts that hold the power steering pump lines to the rack, 1 bolt that holds the steering shaft to the rack, the 2 bolts that hold the rack to the sub frame, and the 2 rear bolts that hold the sub frame up, you need to lower it for extra room.
  6. #6 Re: changing rack and pinion boot 2000 gtp
    I didn't have to take my sway bar off it only took me about an hour and a half the first time I did it. Buy new don't use a jy one unless you like changing it again. I had to do mine twice since the jy one was bad.
  1. 2000 gtp rack and pinion
    By 2000daytonagtp in forum General Tech Discussion
    Last Post: 04-09-2012, 07:42 PM
  2. Looking for a new rack and pinion.
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:43 PM
  3. rack and pinion
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:53 PM
  4. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
