Thread: Air filters
Results 1 to 19 of 19
  1. #1 Re: Air filters
    GTP Level Member
    springfield IL
    I use a k&n.... I just spray light oil on the incoming air side.. I also clean it more often too. Had a maf fail awhile back by using too much oil!
  2. #2 Re: Air filters
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    When i had my GP we had a K&N Air filter in our stock air box for years and never caused a problem, we also cleaned it a few times and i each time we did the car felt better. We then made our own intake, thanks to the info from this forum, and we used a Spectre cone filter for it and that worked fine too. I would suggest the K&N and Spectre, if you have the moeny go with the K&N they are more trustworthy and if your on a budget go with the Spectre. Both do the same thing the only difference is the name. Just remember to clean it every 10-20k miles it and your car will appreciate it, Go to auto zone and for 12$ you can get this air filter recharge kit that comes with two liquid cleaner you can use to clean the filters very very nicely.
    Good luck and hope this helps.
  1. K&N filters bad?
    By Black18Ice in forum General Tech Discussion
    Last Post: 09-02-2009, 11:30 PM
  2. Oil filters
    By TheOtherNick in forum General Tech Discussion
    Last Post: 07-19-2009, 11:17 PM
  3. oil filters dissected
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-14-2009, 10:20 AM
  4. Cone filters
    By bat119 in forum General Tech Discussion
    Last Post: 02-27-2008, 06:00 PM
