Thread: payed 600 for a 97 GT
Results 1 to 17 of 17
  1. #1 payed 600 for a 97 GT
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    picked it up last thursday and been pullin parts off my SE before i send her to the scrapper.
    to lazy to make a photobucket accnt so ive been thinking i might jus post a link from youtube
    with a walk around and run through of my problems. anyone interested in helping me out a bit?
    something jus doesnt feel right, and some opinions would be great.
  2. #2 Re: payed 600 for a 97 GT
    Mar 2012
    NC
    Hello fellow 97 GT owner! Ask away!
  3. #3 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    well, my windshield wipers are in the up right position, they work, and i have another set if need be, but i cant get the damn things to budge. the guy said it may be missing a prong or something. i can get the bolts off, but the wipers wont come off to get to the motor. and i just replaced the water pump from my other 97 and it worked fine on there, never had a problem, now its making a weird sound and im not sure what to think. my temp gauge never gets above 230, gets close when im sitting, then jus goes right back down to normal temp. sorry for the long reply, jus some thoughts.
  4. #4 Re: payed 600 for a 97 GT
    Mar 2012
    NC
    As far as the wipers go, that's a known problem with them, and if you search around you'll find the fix. Off the top of my head, I don't remember what it is otherwise I'd tell you.
    As for the water pump issue, it sounds like you have air in the system. There is a bleed procedure that should be followed after the cooling system is drained and filled. That may be the cause of your high temps. Basically, get the car to operating temperature, open the bleeder on the thermostat housing, close it once a stream of coolant comes out. It may take several tries to get it all but it's the nature of the beast. The noise may just be a pulley or something on its way out. One of the first things I did to mine was replace all the accessory pulleys with new to avoid having one seize and leave me stranded.
  5. #5 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    ive bleed that multiple time, still nothin. coolant runs out a steady stream. still does it.
    and as for the wipers, i cant get the wiper arms off to take a look under the panel.
    any suggestions?
  6. #6 Re: payed 600 for a 97 GT
    Apr 2009
    Fort Worth TX
  7. #7 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    now im gonna see if i can jus bend that tab up with out taking my wipers off. hope this ish works
  8. #8 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    haha, atlast.
    no more windshield wipers in my face anymore.
    thank you rico for posting that video.
  9. #9 Re: payed 600 for a 97 GT
    Apr 2009
    Fort Worth TX
  10. #10 Re: payed 600 for a 97 GT
    SE Level Member wavedout33's Avatar
    Jul 2012
    oklahoma
    Quote Originally Posted by Mikey Bonefas View Post
    any suggestions?
    Wonder if your radiator may be clogged up? Do the fans kick on? Does there appear to be any leakage off the radiator sides or top anywhere?
  11. #11 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    no leakage, and hmm.
    not sure if the fans kick on.
    atleast not to my knowledge anyway.
    what could i do to unclogg and get the fans to work?
  12. #12 Re: payed 600 for a 97 GT
    if the rad is clogged you need a new one.
    do the fans come on when you turn on the a/c, this only works if the a/c works.
    and the fans dont come on normally till like 214 deg.
    when i bleed my engine, i like to let it idle till the fans come on. that way i know the t stat opened up. then bleed it.
    and make sure the heater core is flowing coolant as well. if the heat works your ok, if not flush it and leave it full of water and hook the hoses back up. garden hose works well for this, hose to hose.
  13. #13 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    well my heater only works on 5(max) and i need to recharge the ac system.
    i know why the heater only works on 5, i think.
    its the resistor if im correct?
    and damn. i just junked my other grand prix.
    otherwise i would have pulled the radiator out of that one :/
    but i get pressure in both hoses and im not 100% sure if its clogged or not.
  14. #14 Re: payed 600 for a 97 GT
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    yes resistor, and i have a can to recharge the ac system..
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  15. #15 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    check my other thread. lol
    itll also give ya a chance to check the wheels out.
  16. #16 Re: payed 600 for a 97 GT
    Apr 2009
    Fort Worth TX
    Could be resistor or could be ignition switch.
  17. #17 Re: payed 600 for a 97 GT
    May 2012
    Waterloo, IA
    well im hoping its the resistor. haha still havent gotten around to it. but heres what 600 got me
    and as it sits now
