Thread: Engine Swap Question
Results 1 to 7 of 7
  1. #1 Engine Swap Question
    Aug 2012
    Ohio
    hey everyone, my name is Josh. I just bought my first GP and its a 99 SE. I know its like a few Buicks and Old's but i got a question bout swaping a motor and cant find the answer anywhere else. I need some insight b4 i start spending money.. but its got a 3.1L in it from the factory. Im wanting to swap a 2000 GTP 3.8L S/C into it but wanted to make sure it would bolt right up the the factory engine mounts, i also plan on getting the tranny from the GTP as well but plan on building up the engine/tranny from stock b4 swaping it in. I dont see alot of high hp GP's out there and wanna catch some rice burners off guard and try and win some cash haha.. but any info or links to info would be a big help... thanks
  2. #2 Re: Engine Swap Question
    I'm pretty sure the subframe is the same. Where in ohio are you from?
  3. #3 Re: Engine Swap Question
    Your better off starting with a GTP in the first place, its going to cost alot to swap everything over and make it all work.
  4. #4 Re: Engine Swap Question
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    It's a straight drop in except for things like wire harness, fuel lines, power steering pressure line, axle (hd tranny), and possibly your throttle cable. Been there, done that, got the tshirt.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  5. #5 Re: Engine Swap Question
    Aug 2012
    Ohio
    thanks for the insight guys.. and thanks for the list of **** Rook... and fivefingerdeathpunch, thanks for ur opinion, but i had to get this car, low miles wen i bought it, and only rust is on the skirts, already got a quick fix for that, and the only things im worried about is the engine build, cuz wen i find the 3.8L, im tearin it down to the block and putting all new internals in it. i found a good site thats got everything i need. still gotta do some research on a good combination of crank, cams, pistons, heads, etc. trying to get the most out of it. but trust me, i wanted a gtp but everyone i found was complete ****, owned by kids that dont know how to care for cars.. if you guys no of some good sites i should look at that would be appreciated..................... and dsmuts, im from brunswick...
  6. #6 Re: Engine Swap Question
    Aug 2012
    Ohio
    and Rook, wen i get the wire harness, PS pressure line, axle (hd tranny), throttle cable, should i buy the parts for a '00 GTP?
  7. #7 Re: Engine Swap Question
    I have a wiring harness I'd sell
  1. engine swap question
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2012, 09:50 AM
  2. Engine Swap Question
    By Points70 in forum General Tech Discussion
    Last Post: 04-18-2012, 06:45 AM
  3. 3800 Engine swap question (lesabre to GP)
    By 1gr869 in forum General Tech Discussion
    Last Post: 01-19-2011, 10:50 PM
  4. engine swap question!
    By gagemonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 10:52 PM
  5. engine swap question!!!!
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 12:27 PM
