Thread: 2004 grand prix gt brake problm
Results 1 to 20 of 31
  1. #1 2004 grand prix gt brake problm
    Aug 2012
    florida
    REPLACED MASTER BRAKE CYL . WHEN APPLED FEEL LIKE ON ICE AND KEEP GOING .DID POWER BOOSTER TEST BY FOOT FEEL LIKE OK .WAS DOING THE SAME THING BEFORE. CHECK ALL VACUUM LINES TOO.THE ONE I TOOK OFF LOOKED LIKE SAND IN SIDE AND BLACK AND THICK.WIFE CAR NOT TO HAPPY HELP
  2. #2 Re: 2004 grand prix gt brake problm
    Did you bleed the braking system?
    With replacing the master cylinder you've added air into the lines and you must bleed them.
  3. #3 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    Still same problem bleed the brakes twice.Still feel like i am on ice.I got a better pedal but not stoping like it should.Would speed sensor mess it up too my brother said he read on line maybe it part of it.helppppp pulling my hair out
  4. #4 Re: 2004 grand prix gt brake problm
    next to the master is the abs pump, on that you should find 2 bleeder valves, bleed those 2 first, it may take a while to get all the air out. (just like a caliper) then re bleed the calipers, starting with the pass rear, then the drivers side rear, then the pass front, then the driver side front last.
    i like to use a piece of vac tubing or wiper fluid tube, put the box wrench on the bleeder, then push the tube over the bleeders nipple, and then put the tube in a bottle to let the fluid dump into. nice and clean that way. i do that on the calipers too.
  5. #5 Re: 2004 grand prix gt brake problm
    Wheel speed sensor has nothing to do with brake feel unless abs kicks in.
  6. #6 Re: 2004 grand prix gt brake problm
    Bleeding procedure is
    Right rear
    Left rear
    right front
    left front
    You should use about a big bottle of fluid when swapping a master cylinder.
  7. #7 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    Ibleed the brakes in that order. Ichecked my abs pump it has no bleeders on it .I have a firm pedal and I did the booster test pump pedal 5 times hold pedal down and start car pedal should go down a little meaning that it is working .Let car run 5 min then turn car off and pump pedal 5 times and pedal should rise with pump of pedal and Iget firm pedal
  8. #8 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    3 oz bottle in master
  9. #9 Re: 2004 grand prix gt brake problm
    Ok..so if you have a firm pedal and aren't stopping. Let's ask the next question.
    Did you soak your brake rotor and or pads with brake fluid aka oil?
  10. #10 Re: 2004 grand prix gt brake problm
    i just did some looking around. did you bench bleed the new master? if not thats your problem.
    you new pump should have come with a bleeder kit, 2 hoses tha screw into the exit holes, you loop them into the top and under the fluid line, then with a screw driver, Philips is proffered, you push the piston in and out on the back side of the new master till no bubbles come out of the tubes.
    then install the master.
  11. #11 Re: 2004 grand prix gt brake problm
    heres a vid, not your master but this is how you do it.
  12. #12 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    I have regular brakes they are working I have to push hard on the pedal
  13. #13 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    I did that before I put in
  14. #14 Re: 2004 grand prix gt brake problm
    you lost me now, is your pedal soft? or hard as a rock and dont move down with out a lot of hard pushing?
    if its soft, you still have air in the system,
    if its hard you have no vacuum to the booster most likely. there is a fat hose from the engine to the round booster behind the master cylinder, check that in place also.
  15. #15 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    Thank you I will tell brother
  16. #16 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    Hard a lot of pushing.HAVE TO PUMP THEM TO STOP . I did the foot test for power booster pump pedal 5 times start car pedal should go down a little it did that turn car off and pump pedal 5 times pedal should come up It did that.Also did test with carb cleaner to test for vacuum leaks spray around engine and down the lines to gas tank avap line engine should change sound if leak. On the internet and auto zone advance auto looked. AND THE GREAT HELP YOU AND EVERYBODY ON THIS FORUM
  17. #17 Re: 2004 grand prix gt brake problm
    ok please just answer this question.
    when the cars running and your coming to a stop, is the pedal hard as a rock? or going to the floor?
  18. #18 Re: 2004 grand prix gt brake problm
    Aug 2012
    florida
    Hard as rock. Maybe have to start over again that I did not get all the air out of master.Maybe have to bench bleed over
  19. #19 Re: 2004 grand prix gt brake problm
    Mar 2012
    NC
    Hard pedal sounds like dead booster or bad vacuum to it.
  20. #20 Re: 2004 grand prix gt brake problm
    hard as a rock is a vac problem. like hitman said, make sure the vac hose is hooked up and not leaking. the booster is probably dead.
    next question.....why did you change the master cylinder? because of the hard pedal? or now you have a hard pedal.
    all the small details from the start will help us up to help you, its hard to fix something with 1/2 a story.
  1. 2004 Grand Prix rear suspension squeeks while brake applied
    By eriklynden in forum Brakes/Suspension/Chassis
    Last Post: 06-06-2012, 09:48 AM
  2. 2004 Grand Prix GT1
    By slopez in forum Members Rides
    Last Post: 03-15-2011, 12:11 PM
  3. 2004 pontiac grand grand prix gtp
    By jeffreytatro606 in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 06:23 PM
