Thread: Dash lights not working!!!
Results 1 to 9 of 9
  1. #1 Dash lights not working!!!
    SE Level Member Bessesen2's Avatar
    Jul 2012
    Livonia,MI
    I have a 1998 Grand Prix. Last night i noticed the speedo, tach and so on lights were not working. I went to the store to get new fuses but the guy said it might not be a fuse. He told me to ask around on the forum becuase he had the same car and the same problems. I did change out the cluster fuse from the glove box but it didnt work. Also the climate control lights insted of dimming, just shut off.
    ***I already checked the dimmer under the light controls***
    Any help???
    1999 Grand Prix GTP. 157xxx miles and climbing everyday.
  2. #2 Re: Dash lights not working!!!
    St. Louis
    So did you actually check your fuses or just listen to the guy at the parts store and let it slide? If fuses are good, then I would suspect either a headlight switch or ignition switch.
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    Have you checked all exterior lights, like brake lights, turn signals, head lights, reverse lights and so on. On my 07 I had a reverse light go out and the shifter light and door lights stopped working. Might not be your problem but it won't hurt to check.
  4. #4 Re: Dash lights not working!!!
    Jul 2012
    Livonia,MI
    I checked the fuses. As a stated, i changed a few of them out. if it was the ignition switch from what a heard is that my taillights would not work. I dont know about the headlight switch though
    May 2012
    Fort Campbell, ky
    Did you check the lights themselves not just the fuses? It could be a bulb that went out
  6. #6 Re: Dash lights not working!!!
    Jul 2012
    Livonia,MI
    It's not a bulb because it's not just the gauge lights, also the floor shifter ismt lighting up
  7. #7 Re: Dash lights not working!!!
    Feb 2013
    Florence, Ky
    Im having this same problem, did you ever find a solution? My dash lights/heater lights and all work during the day, but at night they do not.
    Thanks
    Joe
    98 GT Sedan
  8. #8 Re: Dash lights not working!!!
    Jul 2012
    Livonia,MI
    I didn't even mean to fix it how I did, I litterally wiggled and kept turning my headlights on and off and they randomly started working
  9. #9 Re: Dash lights not working!!!
    Jun 2011
    Tempe, Az
    I had the same problem. Come to find out it was the side marker light. Check that.
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  3. dash lights abs and airbag lights flicker
    By reem98 in forum General Tech Discussion
    Last Post: 01-24-2012, 12:37 PM
  4. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
  5. Dash, HVAC lights not working
    By christopher8911 in forum General Tech Discussion
    Last Post: 12-20-2010, 10:02 PM
