Thread: u-bend delete?
Results 1 to 13 of 13
  1. #1 u-bend delete?
    SE Level Member skylar44's Avatar
    Jul 2012
    Toronto
    my resonator is leaking so I'm having that cutout and putting a straight pipe in instead, should I delete the u-bend at the same time since it's all there? Right now I'm currently all stock (GT) but I'm putting in a CAI and overkill pcm soon.
  2. #2 Re: u-bend delete?
    Apr 2009
    Fort Worth TX
    Can't hurt if you're already in there with a sawzall and a TIG welder.
    If your catalytic converter is old you may elect to get the entire cat'ed down pipe that already has the U-bend deleted.
    ZZP sells them for about $200. They're a little cumbersome with the O2 sensor but you could figure it out.
  3. #3 Re: u-bend delete?
    Buy a glasspack instead of just removing the resonator all together.
    These cars sound crappy as it is, deleting the res. will only make it worse.
  4. #4 Re: u-bend delete?
    Jul 2012
    Toronto
    how much would having a 3" catted dp put in run me with labour at an exhaust shop?
  5. #5 Re: u-bend delete?
    If they do it?
    Don't pay for than 40 bucks or so...you will need to get a new upper donut gasket and catback to DP gasket.
  6. #6 Re: u-bend delete?
    Jul 2012
    Toronto
    grrrr why doesn't zzp ship to canada
  7. #7 Re: u-bend delete?
    Because it costs too much and it's a PITA.
  8. #8 Re: u-bend delete?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Some of their garbage can be shipped to Canada. Also check the bay.
  9. #9 Re: u-bend delete?
    Jul 2012
    Toronto
  10. #10 Re: u-bend delete?
    Jul 2012
    Toronto
    ended up doing a res and u-bend delete, I'll do a 3" dp after my next paycheck because my cats are done.
  11. #11 Re: u-bend delete?
    Quote Originally Posted by skylar44 View Post
    Way to make the car rasp.
    Good form, schmee.
    Even after we told you to not get rid of it.
    This new generation listens so well.
  12. #12 Re: u-bend delete?
    Jul 2012
    Toronto
    It's actually quieter than it was with a leak in the resonator and there isn't that much rasp. The welder was also able to salvage my apparently broken o2 sensor by blasting it with a blowtorch. Before there was an annoying drone in the cabin and now the cabin is silent with the exhaust note coming entirely from the tailpipes.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Good form, schmee.
    lol
  1. u bend delete
    By kking89 in forum General Tech Discussion
    Last Post: 05-18-2011, 06:05 PM
  2. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  3. U-Bend Delete?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 12:45 AM
  4. How to.... U bend delete
    By kjclawson in forum How To Write-Ups/Tech Tips
    Last Post: 08-15-2009, 06:00 PM
