Thread: abs testing
Results 1 to 4 of 4
  1. #1 abs testing
    Jun 2010
    canada
    do anybody ever had a problem with there grand prix gt abs light staying on, and test the abs connectors to the hub with a test light i need to know before i do it and also which colour wire to the hub sensor is hot one i think the colours are yellow and green. HELP
  2. #2 Re: abs testing
    Jun 2010
    canada
  3. #3 Re: abs testing
    GT Level Member sic6's Avatar
    san marcos, tx
    Your test light will not light up. you need to use a multimeter to check the voltage.
    97 GTP
  4. #4 Re: abs testing
    SE Level Member wavedout33's Avatar
    Jul 2012
    oklahoma
    my issue was that the pass front hub wires were ripped clean of the plug for the abs...now unfortunately I have to buy a new hub and plug it back in then have my uncle clear any codes with his scanner....
