Thread: 07 speed sensor wheel bearing issue.
Results 1 to 5 of 5
  1. #1 07 speed sensor wheel bearing issue.
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Just bought a car to fix up and sell, my problem is the tcs lights on, service abs on, makes a pretty loud noise when going to left down highway, abs reader said speed sensor in front right wheel bearing. Do I need to get a speed sensor harness or not? Its a 07, 134k miles base model.
    The code was something like c00040.
    The air pressure also said, 132 for all the tires, but the right rear said 0. I thought it was the right rear wheel bearing when i was driving it home, then hooked code reader up and said front right.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  2. #2 Re: 07 speed sensor wheel bearing issue.
    Hubs come with the wire plug in, replace the bearing making noise then figure out if you really need a new harness that leads to the body.
  3. #3 Re: 07 speed sensor wheel bearing issue.
    Aug 2012
    Brainerd, MN
    Ordered a front and rear bearing, see from there. Good deal if thats all i need to do. Is there something wrong with my tire pressure monitoring system? The tire pressures saying 132 and 0 for the one?
  4. #4 Re: 07 speed sensor wheel bearing issue.
    Prolly has 1 dead sensor and the others arent calibrated.
  5. #5 Re: 07 speed sensor wheel bearing issue.
    Aug 2012
    Brainerd, MN
    Ill have to see whats going on, made a pretty bad noise going to left on the highway.
  1. Possible ABS Harness or Bearing Sensor Issue?
    By Dabman in forum Brakes/Suspension/Chassis
    Last Post: 07-15-2013, 04:47 PM
  2. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  3. Cv shaft/wheel bearing issue
    By maverickdog8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2013, 02:29 PM
  4. Speed sensor issue
    By diehl2 in forum General Tech Discussion
    Last Post: 08-10-2012, 08:52 PM
  5. Low speed Wheel Bearing Noise? -97 GTP
    By 3R1CD4V15 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 04:11 PM
