Thread: Ac problem
Results 1 to 9 of 9
  1. #1 Ac problem
    Jun 2012
    Viroqua, Wisconsin
    I have a 2004 Grand Prix and the AC clutch is not energizing. I have checked the AC pressure on the low side and it was at around 150. High. I checked all fuses and relays and replaced them. Still nothing. I cannot find a pressure sensor on the low side. I did find one on the high side and unplugged it. Unplugging it should tell me that I do not have high pressure because the compressor didn't kick in. Any suggestions?
  2. #2 Re: Ac problem
    150 is way to high. It might be overcharged. Has it worked since you owned the car?
  3. #3 Re: Ac problem
    Jun 2012
    Viroqua, Wisconsin
    I am not sure. Is this pressure accurate even though the compressor is not running?
  4. #4 Re: Ac problem
    I'm pretty sure it should never be that high even with the system equalized.
  5. #5 Re: Ac problem
    Check with a real set of gauges and not the crappy ones that come with the cans of r134a. My gauges showed that one girls car i worked on was great around 75ish and on the gauge on the can it was pegged 90+
  6. #6 Re: Ac problem
    Jun 2012
    Viroqua, Wisconsin
    checked it with a good set of gauges and it's high. Around 140. Suggestions?
  7. #7 Re: Ac problem
    recover it and recharge with the correct amount.
  8. #8 Re: Ac problem
    Jun 2012
    Viroqua, Wisconsin
    Thanks for your help dsmut. I took the car to a friend of mine that does AC work and used to work at a auto dealer as a mechanic. Found out that the problem was that the nut that holds the outer clutch plate on was missing and so was the outer clutch plate. Picked up a new clutch plate and it works great now.
  9. #9 Re: Ac problem
    That'll do it lol
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. ICM problem?
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2011, 11:13 AM
  3. New problem
    By ryangtp89 in forum General Tech Discussion
    Last Post: 02-09-2009, 07:58 PM
  4. Replies: 6
    Last Post: 02-07-2009, 01:16 AM
  5. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
