Thread: Knocking Sound from Engine bay.
Results 1 to 20 of 24
  1. #1 Knocking Sound from Engine bay.
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    Well, I broke an axle last night so I finished up my axle install then took the car out for a test drive. Ran great, pulled hard and was nice and smooth. No shakes. Get the car home and shut it off in the driveway. Clean up my tools and the garage and start the car to pull it in.. and its knocking.. Sounds like a flex plate to me, but I may be wrong. I replaced the flexplate last year with a low mile L67 one from a friend. What do you guys think? I got a video.
    ****s broke. - YouTube
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  2. #2 Re: Knocking Sound from Engine bay.
    Mar 2012
    NC
    Sounds like it could be flex plate related. Have you pulled the inspection cover yet?
  3. #3 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    Yep, looked at it and it looks fine, but I can't see all of it. Could be cracked like my old one was around the center.
  4. #4 Re: Knocking Sound from Engine bay.
    Mar 2012
    NC
    That's common on those. You could stick a prybar in there and make it flex. If you hear the scrape of metal, then you found it. I doubt you hurt the engine if you just took it for a spin around the block.
  5. #5 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    I'll drive it till it breaks. I'm not worried about it. I have friends who have driven 6k miles on a broken flex plate, just annoying. I'm pretty sure its the flexplate so I'll replace it if it is but I just wanted other opinions.
  6. #6 Re: Knocking Sound from Engine bay.
    sounded like it went away once you hit a certain rpm.
    I'd check TQ bolts too, maybe one came loose and tq is moving around.
    But it dont sound bottom end to me.
  7. #7 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    Here's my video from last year when my first one broke...
    Bye Bye L67... - YouTube
    So I'm pretty sure it's the same thing. Last time it happened I pulled the motor and threw my cam in, what can I do this time? lol
  8. #8 Re: Knocking Sound from Engine bay.
    Florida
    I'd guess it's the flexplate..I also replaced mine twice...
    But...it also does sound like a chipped piston slapping against the head..(what happened to me, hopefully not to you)
    Sounds very similar, and when I'd rev it, it would stop due to the getting smushed into the head and sticking there, just barely clearing.
  9. #9 Re: Knocking Sound from Engine bay.
    Apr 2009
    Fort Worth TX
    Meziere plates are expensive.
  10. #10 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    That's why I'm not going with a Meziere.
  11. #11 Re: Knocking Sound from Engine bay.
    Meziere plates don't break.
  12. #12 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    Well... the sound isn't there when the engine is cold. Which leads me to believe I spun a bearing.
  13. #13 Re: Knocking Sound from Engine bay.
    spun bearings will knock hot or cold on everyone I've seen.
  14. #14 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    Well I'm not quite sure at this point. My buddy Shawn is coming over tomorrow to get another opinion. But the sound changes when I put it in drive and reverse, so that makes me think flexplate.. lets hope that's all it is.
    mi
    I didn't listen to vid but if it changes from forward to reverse why would it be flex plate? Engine spins same regardless. Is it because the engine and Trans are torquing in different directions?
  16. #16 Re: Knocking Sound from Engine bay.
    GTX Level Member crbquist's Avatar
    Massachusetts
    Sounds like the flex plate.. When mine goes, I'm going meziere.. Fix it once and be done with it
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  17. #17 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    Meziere is also $400... I'm throwing in a GT converter and flywheel.
  18. #18 Re: Knocking Sound from Engine bay.
    Grand Rapids, MI
    It's the flex plate. Found the crack and also got "expert" opinions from Shawn who has broken 10 flexes lol. So it'll be changed this weekend.
  19. #19 Re: Knocking Sound from Engine bay.
    Mar 2012
    NC
    Glad you got it figured out!
  20. #20 Re: Knocking Sound from Engine bay.
    Florida
    Nope, it was a cracked piston and 2 spun bearings. Looks like you gotta sell the car to me as a fixer-upper.
    anyways, glad it was just a flexplate. Make sure to align it properly.
  1. Engine knocking/odd sound
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 08:12 PM
  2. knocking sound
    By casperyaj in forum General Tech Discussion
    Last Post: 03-27-2011, 08:43 PM
  3. knocking sound
    By scott1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 08:46 AM
  4. knocking sound from engine
    By BSP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 09:03 AM
  5. Ticking/knocking sound in engine compartment
    By 200GpGt in forum General Tech Discussion
    Last Post: 04-17-2010, 03:54 PM
