Thread: 1998 GTP snout removal with coupler replacement - oil seapage
Results 1 to 20 of 27
  1. #1 1998 GTP snout removal with coupler replacement - oil seapage
    Donating Users Burgundyman's Avatar
    I decided to service the supercharger by replacing the coupler and adding new oil. I believe the snout was leaking for some time. I bought the coupler from ZZP. I bought their kit which included a syringe and RTV (waterpump and thermostat). Everything went back together nicely. I tightened everything snug and then a quarter turn. In other words, all bolts are tight. Then the unthinkable, I noticed an oil film seeping from under snout. My question is this....Did I use the correct RTV? Should I have let it sit for 24 hours before pouring in oil? I will keep an eye on it. I do not feel like fussing with it again.
    Any assistance is appreciated.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #2 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Did I mention that the engine sounds great again!
    RED- 4 Door Sedan
  3. #3 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    is the leak under the straight down bolt by any chance? mine leaked from there cause the gasket broke off under it, so i rtv'ed the bolt and sent it home, no more leak, how or why i dont know why it leaked from there.
  4. #4 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    I've sealed them up with just plain old red silicone before. I would double check to make sure that both surfaces are flat and even.
  5. #5 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Yes, it appears to come from below the center bolt. The intake gasket did break off. I did not think it would cause an issue. Damn it!
    RED- 4 Door Sedan
  6. #6 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Quote Originally Posted by Slick2500 View Post
    I did scrape and lightly sand. Nothing is leaking from the sides or top.
    RED- 4 Door Sedan
  7. #7 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    RED- 4 Door Sedan
  8. #8 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    You are suppose to use anerobic sealer for the snout to case seal.
  9. #9 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Can you suggest one? I used what zzp sent me, which I thought was odd.
  10. #10 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    It's just this stuff, not sure what ZZP sends or gives.
    https://www.summitracing.com/search/...c-gasket-maker
    My spelling was wrong.
  11. #11 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Antioch, IL
    2009 Challenger SRT8
    Expert at being gay.
  12. #12 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    RED- 4 Door Sedan
  13. #13 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    This is the RTV they sent me
    RED- 4 Door Sedan
  14. #14 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Antioch, IL
    look above and buy it
  15. #15 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Quote Originally Posted by ItHurtz View Post
    I assume ZZP knew their stuff. Apparently not.
    RED- 4 Door Sedan
  16. #16 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    I just found image on Amazon to show you all what ZZP sends in their kit so that others do not have similar issues
    RED- 4 Door Sedan
  17. #17 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    i used black high heat rtv like 6 years ago. no leaks.
  18. #18 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    May 2008
    Schuyler, NE
    It shouldn't leak no matter what you put on there. Take it apart and do it again.
  19. #19 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Do I let it sit for 24 hours before filling with SC oil?
    RED- 4 Door Sedan
  20. #20 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    i never wait for rtv to cure or set up. seal fill drive.
  1. SC snout removal
    By Jaredthefail in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2016, 08:58 PM
  2. coupler replacement
    By Fox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 11:47 PM
  3. Supercharger coupler replacement
    By Beelzeboul in forum General Tech Discussion
    Last Post: 07-25-2012, 08:47 PM
  4. Replace supercharger or the snout &coupler?
    By sav24dl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2011, 01:05 PM
  5. Where to get a supercharger snout rebuild kit? (bearings, coupler, etc)
    By PCweber in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2009, 11:36 PM
