Thread: 1998 GTP snout removal with coupler replacement - oil seapage
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #1 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    It shouldn't leak no matter what you put on there. Take it apart and do it again.
    Just plain old red on mine for years no leaks.
  2. #2 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    i never wait for rtv to cure or set up. seal fill drive.
  3. #3 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Donating Users Burgundyman's Avatar
    Well it should come apart real easily. Wonder if I can salvage new oil or just buy another couple of 4 oz bottles?
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  4. #4 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    id suck out as much as you can if your taking the snout off again, if you cleaned it up good before installing it last time the oil should be fine to reuse.
  5. #5 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Sounds good. Did clean it out well. Will see when I extract it. I'll probably have the bottle on hand anyway for next flush. Thank you.
    RED- 4 Door Sedan
  6. #6 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    Update...I disassembled snout, and scraped away previous sealant. Once both surfaces were fully prepped, I applied "Permatex Anaerobic Gasket Maker (1.69 oz)". I let it cure overnight and added new SC oil this morning. Took it for a test drive. Not a drop of oil. Thanks for all of your timely advice and support.
    RED- 4 Door Sedan
  7. #7 Re: 1998 GTP snout removal with coupler replacement - oil seapage
    May 2008
    Schuyler, NE
    I've put them back together without anything for sealant, and never had a problem.
  1. SC snout removal
    By Jaredthefail in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2016, 08:58 PM
  2. coupler replacement
    By Fox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 11:47 PM
  3. Supercharger coupler replacement
    By Beelzeboul in forum General Tech Discussion
    Last Post: 07-25-2012, 08:47 PM
  4. Replace supercharger or the snout &coupler?
    By sav24dl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2011, 01:05 PM
  5. Where to get a supercharger snout rebuild kit? (bearings, coupler, etc)
    By PCweber in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2009, 11:36 PM
