Thread: 98 GTP supercharger idler and tensioner pulley help
Results 1 to 14 of 14
  1. #1 Re: 98 GTP supercharger idler and tensioner pulley help
    May 2012
    CA
    Thanks for the replies guys. Just to clarify, I want to remove the whole s/c tensioner (spring housing plus pulley), not just the pulley. The spring housing is held by a single torx bolt thru the middle of the spring housing, surrounded by that star shape. I'm pretty sure it's a TORX E8, but it seems like it can strip so easily (I tried it with great pressure in both directions with no luck) so I want to make sure I loosen it the correct way.
  2. #2 Re: 98 GTP supercharger idler and tensioner pulley help
    SE Level Member Dragon1972's Avatar
    It is actually held on to the stud by a 15mm nut, to access it you need a thin wall socket.
    Master Certified Automobile Technician
    1997 GP GT-SC
  1. Supercharger Idler Pulley needs replacing...
    By 87IROCZOWNER69 in forum General Tech Discussion
    Last Post: 02-25-2012, 07:10 PM
  2. Idler&tensioner pulley help
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-15-2010, 10:36 AM
  3. supercharger grooved idler pulley
    By ejechtion54 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2009, 09:20 PM
