Thread: Tire Air Pressure?
Results 1 to 9 of 9
  1. #1 Tire Air Pressure?
    May 2012
    Texas
    Ok, I have a 97 Grand Prix that I got a couple months ago. My Tire Air Pressure Warning is on so I put some air in all tires at 35 psi. The warning light was still on so I put 40psi in each tire but its still on. My tires say 44 psi on them so how much should I be putting in them?
  2. #2 Re: Tire Air Pressure?
    The Boss Iceman6669's Avatar
    Jun 2011
    The light wont shut off till you reset it....
    2011 F-150 Yote powered
  3. #3 Re: Tire Air Pressure?
    May 2012
    Texas
    How do I reset it and I still need to know the correct amount of air to put in my tires.
  4. #4 Re: Tire Air Pressure?
    Jun 2011
    Well if your tires say 44 PSI.... Then put 44 PSI in. And to reset it there is a little button on the bottom of the drivers side dash near the cent console by the radio. It is yellow... Just press and hold for a few seconds.
  5. #5 Re: Tire Air Pressure?
    GT Level Member sic6's Avatar
    san marcos, tx
    The tire pressure spec is located on the driver side door, near the door latch. It recommends 35 psi.
    97 GTP
  6. #6 Re: Tire Air Pressure?
    GT Level Member NR92's Avatar
    Atkins, Ia
    yeah dont put 44psi in them, the psi number on the tire is pretty much what its rated for, you should go off it says inside the drivers door!
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  7. #7 Re: Tire Air Pressure?
    Charles City, IA
    You can run what ever ya want in them, the warning light is just based off revs per mile on your car, so if they are the same it will stay off. I normally run about 40 psi.
    SMGPFC Two Nipple General
  8. #8 Re: Tire Air Pressure?
    Quote Originally Posted by Iceman6669 View Post
    44 PSI is the maximum the tire is rated for.
    35 PSI is a nice compromise between ride and fuel economy.
    Quote Originally Posted by sic6 View Post
    29 PSI for 97-03 IIRC.
  9. #9 Re: Tire Air Pressure?
    Jun 2011
    I run like 35-37 in my 97
  1. Best tire pressure
    By Lambini in forum Tires & Wheels
    Last Post: 06-10-2010, 02:27 PM
  2. tire pressure
    By killbill in forum Tires & Wheels
    Last Post: 12-13-2009, 07:21 PM
  3. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  4. Tire Pressure Warning
    By BHMJohn in forum General Tech Discussion
    Last Post: 09-30-2008, 08:38 AM
  5. Tire Air Pressure
    By 03GPScottyd in forum Tires & Wheels
    Last Post: 08-04-2008, 11:07 AM
