Thread: Stumbling/hesitation issue.
Results 1 to 2 of 2
  1. #1 Stumbling/hesitation issue.
    SE Level Member Peder's Avatar
    Sacramento, CA
    When my car (top-swapped L36 in a GTP) gets hot, such as when driving a long distance or sitting in traffic, it gets to a point where when I give it more than 20 percent throttle, it just stumbles and bogs down and loses any power and starts slowing; and if I floor it during the stumbling, nothing changes. It also builds a little boost (maybe 2 pounds) while it's stumbling/bogging down. It doesn't get any better or worse unless I get off the throttle all together. Last time it did this, it threw an o2 code, so I replaced the o2s (just about a month ago) and it's seemed fine since then, but I haven't been stuck in traffic since then either.
    Boost bypass? TPS? Bad fuel pump? Crank/cam position sensor? The fuel pump is pretty loud, much more than other cars. But a fuel issue wouldn't cause boost to register on the trip computer?
    It's hard to duplicate since I need to basically get stuck in traffic for a while. But if I floor it from a stop, it'll bog down until I release the throttle, and if I roll into the throttle any more than 20 percent or so from a stop, it bogs down. Takes for-freakin-ever to get up to speed when the issue is happening. Any ideas besides rolling it down a hill into the pond?
    It has completely shut off twice in the past 3 months; possibly due to the same issue.
    Cat is out temporarily, so it's not that.
    Luckily I work off-hours and never hit traffic during a normal commute. Ugh.
    Also noticed a "hissing" vacuum leak sort of sound from the brake booster after turning the car off today, but while the car is off, if I press the brake pedal a few times it gets stiff, so that's good, right?
    Peder02
  2. #2 Re: Stumbling/hesitation issue.
    Sacramento, CA
    Finally was able to get a log. I'm not sure what I'm looking at with the TCC Slip, but over 8,000 RPM can't be right..
    http://files.ericwood.net/trannyscan.csv
    Can somebody check it out and let me know if anything seems off? It was the same problem where I step on the gas, and it just bogs down/stumbles, doesn't accelerate at all.
    Peder02
  1. Stumbling on Acceleration
    By dhoeschen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2012, 12:13 PM
  2. 97 prix se stumbling
    By tinted97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2011, 10:26 AM
  3. Random RPM stumbling/stalling
    By Ransom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 01:02 PM
  4. 01' grand prix stumbling
    By 00superduty in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-26-2009, 02:25 PM
  5. Stumbling
    By duane9586 in forum PCM Tuning
    Last Post: 10-28-2008, 08:17 AM
