Thread: The 97-03 W-body buyers guide / Common problems
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 The 97-03 W-body buyers guide / Common problems
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Buying a 97-03 Grand Prix / W-Body?
    So I feel like I answer this question, or see it posted, at least once a week on this and other boards. The W-body platform is getting quite old, and they can be had on the cheap. That being said, there are some things one should look into when buying a used W-body……..
    Electronics
    * Check all windows to make sure they operate; window motor regulators are a common problem.
    * Check all lighting, also check for signs of aftermarket work under the hood. Any modifications to the electrical system, if not done correctly, should be a red flag .
    * The ignition cylinder sometimes malfunctions and won’t allow the key to be removed. This problem is usually associated with a bad brake light sensor located under the brake pedal.
    * Heads Up Display (HUD) may look dim or may not function at all (GTP and GT models). This is caused by some loose solder in the circuit board in the HUD unit itself. It’s fixable in most cases. But a used HUD will set you back about $90.
    Engine
    * Check the area between the lower intake manifold and the cylinder head, if you see coolant pooled, or if you see a black gasket between the two pieces, instead of a silver/metal gasket; consider doing an LIM gasket job first thing after you purchase the car. The plastic LIM’s get deteriorated by the coolant, and start to leak. This replacement is a MUST. Also, if you see coolant, pull the engine dipstick and look at the coolant for signs of “milkshake”, the engine oil will have the consistency and look of a chocolate milkshake when they are combined. Milkshake oil is another red flag Here are a few pictures:
    Old gasket with dexcool damage:
    New aluminum gasket:
    * Coolant elbows. The coolant elbows are located under the alternator, in 98+, there are two plastic elbows. In 97’s and early 98’s, there is only one, as the other elbow is cast into the alternator bracket. These, as being plastic, are also known to deteriorate over time and leak. To check for this, look under the supercharger snout, you will be able to see the one elbow, visually inspect it to see if it is indeed leaking. On the n/a L36 motor (non-supercharged), the elbow is located in the same place:
    * Dexcool…….. It’s the scum of the automotive industry. GM’s attempt to engineer a fluid that would last 100K+ really backfired on them. Pop the radiator cap and look at the coolant, if it is any other color but orange………….you’re in trouble. Many people mix regular coolant with dexcool, not knowing that it causing a chemical reaction and will clog up most of your coolant system and do a lot of damage. If the coolant is brown/sludge, well, it doesn’t take a rocket scientist to know that fluid shouldn’t look like that. Be prepared for hefty repair bills.
    * Valve cover gaskets – GM issued a recall for some models, but not all….and unfortunately they are usually all bad. Look for signs of weeping valve cover gaskets, usually moist with oil right under the valve cover on the cylinder head. You WILL need to replace these gaskets, not a hard job, definitely not a deal breaker either. If the leak is bad enough, you may also smell some burning oil, that’s usually from the rear bank valve cover dripping onto the exhaust manifold.
    This is a perfect example of what to look for:
    * Oil pan leaks – Another common problem with the 3800 engine. Crawl under the car and look up at the oil pan, if you see oil around the pan where it bolts to the block, you have a leak. This is NOT an easy fix, and requiring the lowering/removal of the subframe. Most of the time, this leak isn’t very serious, but it’s still a leak.
    * Fuel fittings – This is a problem more associated with N/A cars, but still can be found in supercharged applications. Locate the fuel rails on top of the engine, then trace the fuel line back to the firewall, the fuel lines are black plastic hoses. Now, look at the seal between the fuel line, and the fuel rail…. Be mindful if you have a leak, and you buy the car! That problem needs immediate attention!!!
    * Aftermarket upgrades- This is a sore subject with many members. I personally prefer to purchase a vehicle with no upgrades, since I don’t know who did the upgrades, how it was done, and if any shortcuts were used. That being said, purchasing a W-body with some upgrades isn’t a bad thing, just be careful and understand what is done. If you had the sense to find this discussion board, have the sense to post up a modification list and see if the members feel that it wouldn’t have done damage to the engine.
    * Regular engine check – Do the same type of check you would do with any other car! Check the engine oil, fluid levels, etc, etc. If there is any ticking or knocking, don’t buy the damn car!!!!
    During your test drive, be sure to give the engine a good, broad RPM check. If it feels like its hesitating or doesn’t have power, RED FLAG
    TRANSMISSION
    I highlighted this section because it is indeed, the weak point of this platform!!! If I were to go into specifics in this section, it would be a few pages long. So what I’ve done is make a list of symptoms you may experience during a test drive, if you do encounter any of these, be prepared to rebuild and/or replace the transmission in the near future!!! All of the w-body boards have great transmission sections that can assist you in diagnosing your specific problem:
    * Long, hesitating shifts
    * Hard shifting
    * Pre-mature torque converter lock-up (when cruising anything less than 45mph, torque converter locks and RPM’s dive down)
    * Shuttering or loss of power when going up an incline or cruising around 35-45mph
    * Erratic up shifts or slipping gears
    * No 4th gear
    * Brown or burnt smelling fluid
    * Any banging or odd noises coming from transmission case when in Park
    * Leaking fluid
    What TO look for:
    * Nice, clean, red transmission fluid
    * Smooth, easy shifting
    My suggestion, go on a nice, LONG test drive. Let the transmission warm up to operating temperatures, and then just test it out! Do some heavy throttle runs, go up some hills, just test the transmission and see what it does. A lot of these problems get worse as the transmission heats up, so if the seller won’t let you go for a long ride, well, that’s a RED FLAG
    Suspension/Steering
    * Bad steering rack / Power steering pump - Look for odd, whining sounds coming from the steering, especially when turning the wheel. If you have any problems turning it, that’s a problem. Unfortunately, the pump is an easy fix, whereas the rack is an extensive project. It’s not very easy to tell which one is the problem either, so if there’s a steering issue…….. RED FLAG .
    * Cracked front sway bar – Another common problem, they usually crack right where they connect to the control arms, at the bushing. Look for signs of splitting at the ends of the bar.
    * Bent rear trailing arms – This usually occurs when the previous owner uses the rear trailing arm to jack up the rear of the car, resulting in some pretty serious damage, the trailing arms are right behind the wheels, and connect to the frame of the car to the rear wheel hub. Look for this:
    This is what they should look like:
    * Bushings and end links – I could list every bushing or rubber grommet you should check, but the list would go on and on and on….. Here are a few important ones, as a potential buyer, you should be checking most of these anyways: top engine mounts, subframe bushings, sway bar end links, ball joints, control arm bushings.
    * Axles – This is another common problem, but it’s not necessarily the axles that go bad, it’s the CV joints and boots. Look for some “rooster tail” spray of grease on the underside of the hood near the belts, look down past the belts and to the left (towards the firewall), you should be able to see the passenger side boot, inspect it for rips or tears. Also inspect the DS boots. There are two boots on each axle.
    During your test drive, go through a few nice corners, make some tight turns, listen and feel for anything out of the ordinary, odd sounds, shaking in the steering wheel, pops or thuds when going over bumps….
    Interior
    * General care and maintenance – A lot of the GP or other W-body interiors are cheap plastic and fake leather………look for obvious cracks in pleather seating, test seat heater, cup holders, HVAC controls, etc, etc. You can expect a good amount of creaking from this interior, but anything super annoying is something you should inspect further.
    HVAC / Heating
    * A/C not blowing cold – Haven’t we all bought a car that the AC hasn’t been cold? Unfortunately on the W-body, it’s not always as easy as “put Freon in and go”…….. a few things can be wrong here. Blend door actuators not functioning will cause cold air on one side of the cabin and not the other……but a gunked up orifice tube will give the same symptoms.
    * Metal scraping sound when A/C is off, but goes away when its turned on - If there is a sound from the engine, but when you put the A/C on, it stops, you’re bearings in the A/C compressor and compressor clutch are shot.
    * Fan will only work on highest setting or not at all / fan makes horrible noise when turned on – Common problem, most W-bodies didn’t come with a cabin filter installed from the factory, so water gets down into the fan assembly and will seize it. Also, there is a controller that can go back and will keep the fan from working at any other setting but high.
    During your test drive, crank that A/C!!!! Also, play with the HVAC controls, change the settings, make sure you go through all the different settings and note any problems. Put the heat up on high and check that the defroster functions correctly.
    Body panel rust
    * Rusted rear strut tower – This has been happening more often to cars in the “salt belt”, open the trunk and look back towards the strut towers, pull back the carpet and inspect the top of the tower for signs of rust.
    * Fuel door - Directly under the fuel door, there is a small piece of insulation that becomes soaked with water / debris / salt, over time it eats away at the panel and rust begins to show on the exterior of the car.
    * Above windshield and rear window – Another rust prone area; look right above the seal of the front/rear windows for any bubbling paint or rust.
    * Rocker panels / lower door – The rocker panels are notorious for rusting out, crawl under the car and look at the rocker panel from behind the body molding, you’ll be able to see any signs of rust. Also the lower parts of the doors are known to rust, with the door open, look underneath them.
    * Wheel well / fender – Also inspect the wheel wells, they are known to rust, especially the rear wheel wells.
    Keep in mind when inspecting for rust damage, you may NOT be able to see it through the paint……..yet. Most of the rust problems on this platform start from behind the panel, so one would not necessarily see it until it’s too late. If you do a thorough inspection, you should be able to pin point these issues.
    Well, that’s my write-up! Big thanks to the guys in the GPF.com chat box for spit-balling some ideas for this write-up. If anyone has anything they think I should add to this, please feel free to reply. Remember though, this is just a guide for someone that knows nothing about the platform to look at when inspecting a possible car purchase. I can’t say this is the” be all end all” list, as I’m sure I missed some things. Also, each car is different, some less common problems can be evident, and as a possible purchaser, you should address them as necessary.
    For all your 3800 needs:
  2. #2 Re: The 97-03 W-body buyers guide / Common problems
    Ohio
    good job jason. im sure this will help many people out when looking to buy one
  3. #3 Re: The 97-03 W-body buyers guide / Common problems
    Michigan
    Thank you for this write up! Very detailed, helps a lot!
  4. #4 Re: The 97-03 W-body buyers guide / Common problems
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    I vote sticky. Good work!
    02 sedan, top swap
  5. #5 Re: The 97-03 W-body buyers guide / Common problems
    very nice. gonna move this to general GP discussion. we (mods) will also be editing and adding, so it seems.
  6. #6 Re: The 97-03 W-body buyers guide / Common problems
    Orange County, NY
    Thanks for moving it.
    I didn't ask for an editorial though.......if the mods want something added, I'd appreciate a simple reply to my post.
  7. #7 Re: The 97-03 W-body buyers guide / Common problems
    Mar 2012
    Ontario, Canada
    Thanks for posting this about a week too late. Good info though. I'll have to looking it over again after I pick the car up.
  8. #8 Re: The 97-03 W-body buyers guide / Common problems
    Fix the HUD section.
    Alot of GT cars had HUD, no se model had them
  9. #9 Re: The 97-03 W-body buyers guide / Common problems
    we've got a discussion going around in the mods section about how we want it to be in the end. might be a thread with a plethora of links attached to it. we won't change any of your content.
  10. #10 Re: The 97-03 W-body buyers guide / Common problems
    Donating Users vegasridercc's Avatar
    Carson City, Nevada
    Kudo's
    will use as a reference for future maintenance..
  11. #11 Re: The 97-03 W-body buyers guide / Common problems
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    Does anyone have any pictures of this scenario?
    I am wondering how do you tell and what do you do if they are?
  12. #12 Re: The 97-03 W-body buyers guide / Common problems
    SE Level Member Bessesen2's Avatar
    Jul 2012
    Livonia,MI
    Wish i would have veiwed this before i bought mine. I have a 1998 and unfortunatly the gaskets were shot. Ended up having to replace the whole motor with a 2005. Runs great now! I never knew how many problems these cars had. Thanks
    1999 Grand Prix GTP. 157xxx miles and climbing everyday.
    Orange County, NY
    Quote Originally Posted by andremike View Post
    Well, I think he explained it pretty well. You pull back the carpet in the trunk and look at the towers. Look for paint bubbling or discoloration.
    They can be repaired, but it's labor intensive and not many welders like to climb in the trunk ;-)
    This post brought to you by.....
  14. #14 Re: The 97-03 W-body buyers guide / Common problems
    SE Level Member Garrett Mofford's Avatar
    Oct 2012
    Cincinnati
    so my fluid is brownish orangeish kinda nasty looking.. should i just flush the whole system and also do i have to use the dexcool again or is any 50/50 good enough?
  15. #15 Re: The 97-03 W-body buyers guide / Common problems
    Grand Rapids, MI
    When you do your lim job Garrett, you're going to lose coolant anyways. So it's best to just go ahead and flush the system and replace with 50/50 coolant. It is up to your discretion if you want to use conventional green or dex. I personally run green.
    And let's try to keep all of your info in one thread, yes?
  16. #16 Re: The 97-03 W-body buyers guide / Common problems
    Oct 2012
    Cincinnati
    Quote Originally Posted by brandonl2000 View Post
    also with winter approaching.. is 180 stat good?
  17. #17 Re: The 97-03 W-body buyers guide / Common problems
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Quote Originally Posted by Garrett Mofford View Post
    I believe my '01 GT has a 180* thermostat in it (not my doing...bought it like that). In the winter, my check engine light comes on. Code says that the engine is not reaching normal operating temperature. This is due to the 180 thermostat.
  18. #18 Re: The 97-03 W-body buyers guide / Common problems
  19. #19 Re: The 97-03 W-body buyers guide / Common problems
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    vBulletin Message
    No Thread specified. If you followed a valid link, please notify the administrator
  20. #20 Re: The 97-03 W-body buyers guide / Common problems
    Oct 2012
    Cincinnati
    i got it! dude im a rookie here lol im still figuring out how you guys do stuff around here
  1. BuYERS WATCH OUT
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-03-2011, 01:04 AM
  2. What would you do? Buyers in FS Sale
    By BlownBigBlock in forum The Rant Forum
    Last Post: 01-21-2010, 07:38 PM
  3. Common Problems??
    By jayrayllc in forum General Tech Discussion
    Last Post: 11-01-2009, 09:49 AM
  4. Common Problems?
    By deadmittens in forum General Tech Discussion
    Last Post: 09-28-2009, 12:31 PM
  5. Common Grand Prix problems?
    By TronCarter in forum General Tech Discussion
    Last Post: 03-04-2009, 04:38 PM
