Thread: oil pan drip
Results 1 to 20 of 33
  1. #1 oil pan drip
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    hey guys, i just found out today my oil pan is leaking a drop every 2 seconds. thats pretty bad. I was wondering if anyone had any tips on how to take this bad boy out. Maybe you guys learned some stuff after you replaced them. Thanks
  2. #2 Re: oil pan drip
    Ohio
    dropping the pan you mean?
  3. #3 Re: oil pan drip
    yes.. i have no idea how to do this. and do not own a engine hoist. was wondering if there was another way
  4. #4 Re: oil pan drip
    Dropping the subframe.
    It sucks.
    Enjoy.
  5. #5 Re: oil pan drip
    It sucks.
    Enjoy.
    Said this in chat.
    Lots of fun.
  6. #6 Re: oil pan drip
    Ohio
    yeah drop the cradle and use something to support the engine. usually you can use a 4x4 across the fenders. the passenger side engine mount bracket will make you wanna shoot yourself if you leave the cradle on
  7. #7 Re: oil pan drip
    Ohio
    i really wish i would have pulled the engine when i did mine. would have been so much easier
  8. #8 Re: oil pan drip
    you guys think i should try out JB weld before i go trying to do this
  9. #9 Re: oil pan drip
    Ohio
    if you can find where its leaking sure.. id drain the oil before you go sticking weld on there.
  10. #10 Re: oil pan drip
    yeah im going to take a look tomorrow
  11. #11 Re: oil pan drip
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    U sure its ur oil pan gasket and not just oil dripping off the pan. Dripping oil every two seconds from a gasket leak seems pretty fast and bad. Sometimes ur oil sending unit could be doin that
  12. #12 Re: oil pan drip
    well im not sure what it is, but yes its dropping off the pan. But my only guess was the oil pan gasket. Never heard of the oil sending unit. Where is that located
  13. #13 Re: oil pan drip
    St. Louis
    The oil sending unit screws into the side of the filter adapter, where the oil filter screws onto. Should have a 2 wire connection sticking out of the side pointing towards the firewall. Often the sender will leak when it goes bad. If you remove the electrical connection to it an oil comes out or it look wet inside then its shot.
    Here's a pic
  14. #14 Re: oil pan drip
    Nov 2010
    Illinois
    the thing about oil is that it gets AAAAALLLLLLLL over the place. so your best bet is to clean it as best as you can and follow the trail
  15. #15 Re: oil pan drip
    That, or is the level sensor in the very front of the pan itself...but yeah, drain oil...clean the piss out of the entire pan with brake clean...and the level sensor, and the pressure sensor, and then...fill with oil...and start it and take a look around there while its running, see if you can see anything. That would be my first plan of attack...TBH.
  16. #16 Re: oil pan drip
    okay so i found the drip, if you can see that green rubber circle around the bolt.. This picture is taken from the passenger side wheel
  17. #17 Re: oil pan drip
    any idea what that bolt is?
  18. #18 Re: oil pan drip
    St. Louis
    That would be the oil pressure sending unit I referenced in the pic above.
  19. #19 Re: oil pan drip
    Portland Oregon
    If you're talking about the oil pressure sensor (the only thing something green plugs into where you're looking) that's exactly what Fordman posted on post 13. Also, it's gross in there, how can you tell that's where it's leaking from when it looks like someone set off a grease bomb?
  20. #20 Re: oil pan drip
    the thing with the green on it, is the oil pressure switch, its like a 7/8th wrench or something, I know its big.
