Thread: 99 gtp running horrible need help
Results 1 to 8 of 8
  1. #1 99 gtp running horrible need help
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    So my 99 gtp 179k runs weird. Its kinda hard to explain so please try to work with me. I've tried searching scouring the internet and I just don't know so here we go. Say I'm cruising down the road going 35mph, slow down to like 10 bang a corner and get back on it, it loses power. Like I get on it and the rpms drop then shoot up like 3k and it goes. It sounds like **** to. Then today I was going 80 oon the highway and lightly on the gas to keep speed the rpms were jumping from around 2600 to 3000 surging seeming like a missfire but no codes. I've checked plus, wires, coils,changed fuel filter,I did a compreson test, I'm pretty sure all my vacum lines are good. I'm at a brick walll with this. Its gotten worse over the past 2 weeks. Any help / sugestions arre much needed and appreciatted. Matt.
    Smgpfc
  2. #2 Re: 99 gtp running horrible need help
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Pretty sure this is all transmission related. The surging is the TCC if I remember right. The rpms shooting up is either clutch or TC slippage. I'm sure someone will chime in with the exact diagnosis, but it's not your motor.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  3. #3 Re: 99 gtp running horrible need help
    Dec 2010
    plymouth ma
    anyone else deal with something similiar?
    Smgpfc
  4. #4 Re: 99 gtp running horrible need help
    St. Louis
    Yep. My RPMs surge sometimes too. Usually more prone to do it when in 3rd or 4th under a load (like going up a hill) and I give it some gas. Mine doesn't loose power around the corners though.
  5. #5 Re: 99 gtp running horrible need help
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    Could be a MAF acting up or a TPS. It's not outside the realm of possibility. My son's 95 olds was doing something similar, we changed the MAF and it stopped.
    4 out of 3 people have trouble with fractions
  6. #6 Re: 99 gtp running horrible need help
    40-15'30'' N 085-40'33'' W
    Maybe the converter is locking and unlocking. Do you have access to a tech2 or good scanner that can live data stream? If so hook it up and go for a drive while monitoring the transmission parameters. See whats going on there if any of the readings are eratic.
  7. #7 Re: 99 gtp running horrible need help
    Most commonly this is ignition related. You said you checked the plugs and wires. How did you check them?
  8. #8 Re: 99 gtp running horrible need help
    SE Level Member 99gtp3's Avatar
    Apr 2012
    mn/wi
    My Car started to do this i think wen i put My own cold air intake on think i messed with maf sensor?
  1. Horrible gas mileage - help!
    By aziff in forum General Tech Discussion
    Last Post: 05-02-2011, 07:14 PM
  2. Horrible mileage
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2011, 10:59 PM
  3. Car getting horrible MPG
    By Mercenary in forum General Tech Discussion
    Last Post: 02-02-2011, 10:42 PM
  4. horrible gas mileage!
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2010, 12:06 PM
  5. Replies: 12
    Last Post: 10-16-2010, 08:09 AM
