hey guys, i just found out today my oil pan is leaking a drop every 2 seconds. thats pretty bad. I was wondering if anyone had any tips on how to take this bad boy out. Maybe you guys learned some stuff after you replaced them. Thanks
Dropping the subframe.
It sucks.
Enjoy.
yeah drop the cradle and use something to support the engine. usually you can use a 4x4 across the fenders. the passenger side engine mount bracket will make you wanna shoot yourself if you leave the cradle on
U sure its ur oil pan gasket and not just oil dripping off the pan. Dripping oil every two seconds from a gasket leak seems pretty fast and bad. Sometimes ur oil sending unit could be doin that
well im not sure what it is, but yes its dropping off the pan. But my only guess was the oil pan gasket. Never heard of the oil sending unit. Where is that located
The oil sending unit screws into the side of the filter adapter, where the oil filter screws onto. Should have a 2 wire connection sticking out of the side pointing towards the firewall. Often the sender will leak when it goes bad. If you remove the electrical connection to it an oil comes out or it look wet inside then its shot.
Here's a pic
That, or is the level sensor in the very front of the pan itself...but yeah, drain oil...clean the piss out of the entire pan with brake clean...and the level sensor, and the pressure sensor, and then...fill with oil...and start it and take a look around there while its running, see if you can see anything. That would be my first plan of attack...TBH.
That would be the oil pressure sending unit I referenced in the pic above.
If you're talking about the oil pressure sensor (the only thing something green plugs into where you're looking) that's exactly what Fordman posted on post 13. Also, it's gross in there, how can you tell that's where it's leaking from when it looks like someone set off a grease bomb?
