i have a 97 gtp and it sounded like a bad bearing was coming from the right side of my engine (belts side) so i pulled off both belts and checked all the pulleys and the AC was the one that was making the noise i put a lil oil on the AC pully started it up after i put the belts back on and still made noise. when i would turn on the air the noise would stop. anyone ever have this problem before? if so do i need to replace the whole AC compresor or is it possible to just replace the pulley? i have a blown up l67 with good externals on it so i have the whole AC set up.
