Hey anyone got radiator replacement info?
Based on your sig pic. I'll say 97-03
1. Remove dogbones and let engine sit back. (15mm)
2. Remove fans from radiator, one 10mm top, one on each side of the rad, plus electrical connector.
3. Drain coolant. I'd use the lower rad hose.
4. Unhook rad hoses
5. Unhook trans lines (either 16/17mm or clip style)
6. Remove plastic clips holding wiring to rad support
7. Remove radiator hold downs (10mm, one on each side)
8. Gently wiggle and remove radiator.
4.
