Thread: Is something wrong with my car/suspension?
Results 1 to 20 of 21
  1. #1 Is something wrong with my car/suspension?
    40-15'30'' N 085-40'33'' W
    Ok, ive had my car on a lift twice and gave it a good look over and didnt see anything wrong.. But my car seems like it sits higher in front than normal. There is a 1 5/8" height difference front to rear. Is this big of a difference normal!? Here is a pic for refrence
  2. #2 Re: Is something wrong with my car/suspension?
    thats the rear end sagging, new struts should fix that.
    oh and they all sag in the ass, even my regal.
  3. #3 Re: Is something wrong with my car/suspension?
    May 2008
    Winnipeg, MB
    Looks like your ass end is heavy! got subs?
    2007 Pontiac Grand Prix
  4. #4 Re: Is something wrong with my car/suspension?
    I know they all sag. My dad has had 3 grand prix's ad this is y second one. My first one sagged so i bought brand new gm coils and struts and it still sagged. No subs.. Thats just how it sits. My concern is that if i lower it i dont want it to sit ass down. I want a nice level car.
  5. #5 Re: Is something wrong with my car/suspension?
    search around the suspension section, not to long ago (days ago) the same topic came up and i forget what brand they were saying hold the back up better with out the sag.
  6. #6 Re: Is something wrong with my car/suspension?
    I found a set from SSC that only lower the front but offer more support for the rear incase you have subs or whatever in the rear.
  7. #7 Re: Is something wrong with my car/suspension?
    Springs.... Springs support the mass, struts dampen the movement.
    Quote Originally Posted by tod1d View Post
    They do that on their own.
    Quote Originally Posted by Jackblack99 View Post
    You know the instant you touch the throttle the rear end squats?
    Intrigue springs.
    They lower the rear, but not as much as the standard lowering springs.
  8. #8 Re: Is something wrong with my car/suspension?
    Quote Originally Posted by matt5112; [/QUOTE
    Yes i know it squats under acceleration. But the car clearly isnt accelerating in the pic. I just dont want that gay ass stance and dont want to drop my money on some springs if its still going to sit that way. My reason for the post was to find out of other guys with stock suspensions have that big of a difference front to rear. Cause almost 2" is a lot in my book. Im not driving a desert running prerunner so i dont want it to sit like one. I just want to know what kind of springs to get that will lower the car but yet net me a nice level stance.
  9. #9 Re: Is something wrong with my car/suspension?
    olds intrigue springs level it out.
  10. #10 Re: Is something wrong with my car/suspension?
    And just to clarify.. Im not wanting to raise the rear to get it to set level
  11. #11 Re: Is something wrong with my car/suspension?
  12. #12 Re: Is something wrong with my car/suspension?
    Either way the car seems to sut abnormally high in the front.. Even for a car typically sits ass down.
  13. #13 Re: Is something wrong with my car/suspension?
    What size tires are those?
    Are you sure those are stock springs?
    Measure the distance between the centre of the wheels to the top of the fender.
    No one sells just one axle worth of lowering springs.
    So if you want to bring the car level, any set of lowering springs should suffice.
    If you have any permanent heavy fixtures in the trunk, I'd suggest SSC sound system springs.
  14. #14 Re: Is something wrong with my car/suspension?
    There isnt anything in the trunk. I dont plan on having a system or anything like that. The tires are too small.. Im just running them for now because they have good tread. They are 245/45/17's. I think im gonna go to a 255/50/17 when i get tires. I was actually looking at the SSC springs you mentioned. I just wanted to get some opinions from others on the stance of my car before i bought springs. If my suspension stance isnt normal i dont want to buy springs. I want to make sure everything is correct before i buy springs.
  15. #15 Re: Is something wrong with my car/suspension?
    255/50r17 would have the opposite effect, they're too tall.
    The springs are most likely whats causing the issue in combination with your undersized tires.
    http://www.grandprixforums.net/want-...ere-28165.html
  16. #16 Re: Is something wrong with my car/suspension?
    Yoga city
    hate to ask but open the trunk and look at stut mounts and see if rust has eaten away at them, mine was sagging and that what it ended up being
  17. #17 Re: Is something wrong with my car/suspension?
    I want some tires taller than these. And ill check the mounts. But i would think that if the mounts were rusted they would make some racket... My car doesnt make any noises
  18. #18 Re: Is something wrong with my car/suspension?
    If the 255/50's will be too big what size should i get? These are shorter than stock, i dont like how short the sidewall is and they make my speedo read incorrectly. I want more tire.. So what size should i go with then?
    225/55R17.
    More tire is just for looks.
    Won't help with traction.
  20. #20 Re: Is something wrong with my car/suspension?
    Thats why i want a taller tire. I never said anything about traction issues. I want a bigger tire so i have more sidewall and so im the same size or close to stock size so my speedo is correct.... Its a 9" wide wheel. I have plenty of width for traction. Just want a little more height. So why would i go with a 225? Thats narrower than my 245's.
  1. WTF is wrong with this guy....
    By MrPoopyButthole in forum The Rant Forum
    Last Post: 04-06-2011, 07:07 PM
  2. Is Something Wrong With My Tie Rod? (pic)
    By SuperSport in forum General Tech Discussion
    Last Post: 07-30-2010, 09:03 PM
  3. What Else Will Go Wrong?
    By GrandPrixChic02 in forum General Tech Discussion
    Last Post: 07-24-2010, 09:32 AM
  4. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  5. WTF am i doing wrong
    By 04 GTP COMP G in forum Forum Bugs/Suggestions
    Last Post: 12-29-2008, 05:43 PM
