Thread: Easy cold air upgrade
Results 1 to 20 of 37
  1. #1 Easy cold air upgrade
    SE Level Member dieslsmoke's Avatar
    Jan 2012
    Idaho
    So I've been reading about the CAIs people have been building, took apart the stock system and came up w/an easy solution. Get a 6"Spectre filter and about 8" of 3.5" exhaust pipe. Put the exhaust pipe in the stock tube as a sleeve up to the IAT. It as a pretty tight fit but can be done. There should be an inch or so sticking out of the end, just put the factory clamp back on and clamp the new cone filter on the pipe. It seems the only bad thing about the factory setup is the corrugation causing disruption to the airflow, the sleeve should take care of this and give the aftermarket filter something hard to clamp to. I am hoping the stock tube will work as an insulator to the tube reducing temps and the IAT stays in the factory location with no drilling or modification.(It is dark and raining or I would get pics)
    2001 Grand Prix GT
    ZZP Hiflow downpipe w/cat, Summit mufflers
    Factory modified Cold Air Intake
  2. #2 Re: Easy cold air upgrade
    a lot of people have done this. i don't exactly like it because the stock corrugated hose is pretty unappealing, but it does work.
  3. #3 Re: Easy cold air upgrade
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Seriously? I mean I've seen a ton of people slap a filter on the end of the stock corrugated hose.......but to insert a piece of exhaust pipe into it first????
    For all your 3800 needs:
  4. #4 Re: Easy cold air upgrade
    Out West
    wrap duct tape around the stock corrugated hose.
    Whine with your Cheese?
    It's usually pvc that is used.
  6. #6 Re: Easy cold air upgrade
    Ohio
    yeah on my original setup i used 3.5 pvc inside the corrugated hose, then i stepped up and did 4" from the tb to the cone
  7. #7 Re: Easy cold air upgrade
    Pennsylvania
    6" filter? pfffft.
  8. #8 Re: Easy cold air upgrade
    Jan 2012
    Idaho
    So far I like the setup, I had the pipe laying around so it wasn't that big of a deal to get. Finished removing the air box and installed my junkyard S10 PCM tray. I hope this thread gives people different ideas for aproaching a project. I like that the people on this forum aren't just a bunch of bolt on fanatics but like to think their way thru things.
    2001 Grand Prix GT
  9. #9 Re: Easy cold air upgrade
    SE Level Member natejames99gtp's Avatar
    st.cloud minnesota
    just looking at your picture and wouldnt you cai work better if you extended it out further to the drivers side fender to get further away from the engine so your actually able to get some cold air? im jw i have thought bout doing some similar stuff to my car
  10. #10 Re: Easy cold air upgrade
  11. #11 Re: Easy cold air upgrade
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    cold air doesnt matter. more air is what matters.
    I disagree.
    Strongly.
  12. #12 Re: Easy cold air upgrade
    SE Level Member 07GPBase's Avatar
    Sep 2011
    Ohio
    Just a quick question.....is it possible to plumb the CAI cone down to the bottom of the radiator? I've seen alot of Firebirds and T/A's (Of course the radiators in them are angled so it might be easier to do) and have been told that is where you will find the best cooler, cleaner, sufficient air flow. Now, this is what I've been told so don't crucify me too much for mentioning this LOL. Just wondered and I know everyone has their own opinions. And I'm going to be doing a set up on my 07 but from my research from the posts and threads I've read I have gathered that the best way is the Wiz box for the 04+ GP's. But I'm the type that gets 2nd, 3rd, 4th and maybe even a 5th opinion if I'm still unsure (after all this is my DD)
  13. #13 Re: Easy cold air upgrade
    Quote Originally Posted by mechguy View Post
    I disagree.
    Strongly.
    you can keep your 3 ponies. im all about no effort.
  14. #14 Re: Easy cold air upgrade
    new britain, ct
    http://www.grandprixforums.net/dyno-...ake-33225.html
    have we forgotten about this thread?? lol
    07 Black GXP.
    Quote Originally Posted by 07GPBase View Post
    Destroy ze filter with water.
    It'd also have to be in front of the rad.
    I disagree.
    Strongly.
    When you're moving it won't matter.
    Under 40 mph you'll lose some power.... But I'm having traction issues there so I don't care.
  17. #17 Re: Easy cold air upgrade
    This.
    Jan 2009
    Tallahassee, FL
    that was the first intake setup I had, then I bought a 45* elbow, some piping, and made a cheap FWI.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  19. #19 Re: Easy cold air upgrade
    Jan 2012
    Idaho
    I found some 4" aluminum tube off a 2ton diesel truck with a 22* bend in it, puts the filter right at the fender buuuuut, I'm worried the aluminum might absorb to much heat from the engine bay.
    2001 Grand Prix GT
  20. #20 Re: Easy cold air upgrade
    no matter what the intake is made of, it will get heat soaked.
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. Easy come, easy go...
    By stinky in forum Off Topic Discussion
    Last Post: 02-29-2012, 09:18 AM
  3. Easy brake upgrade question
    By Elite6 in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2011, 05:35 PM
  4. That was easy...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2008, 11:47 AM
